Whisky mash
Posted: Wed Jan 01, 2014 10:14 am
by Horsecreek shine
Here is one I have made several times that turns not to shabby
12 lbs of flaked maze I use this as it's already converted and easy to mash in malt grains
2 lbs of 6 row barley that will need to be crushed
2 Lbs of rye malt that will also need to be crushed as well
I also use enzymes an ph buffer in the strike water
Mash in between 140-150 deg and try to maintain at 145 deg for 90 min
Then sparge or strain i usually get a S.G about 1.080 -1.072 let cool to yeast pitch temps
Or cut with water make a thin mash to get temp down quicker for a faster pitch I've done this both ways
And get typically the same results
I welcome any info or improvements y'all might have
Happy shinin
Re: Whisky mash
Posted: Sat Jan 18, 2014 12:01 pm
by WillC
I think i will try your recipe.
But how much water total is used for this recipe?
Re: Whisky mash
Posted: Sat Jan 18, 2014 1:46 pm
by ohyeahyeah
Your grainbill is THE stereotypical bourbon grainbill. 75/12.5/12.5
It's not original, but it is so popular for a reason. It's damn tasty. It's even tastier if about 1/3 of your water is still slop.
Re: Whisky mash
Posted: Sat Jan 18, 2014 9:53 pm
by DistillIT
Horsecreek Shine
Nice recipe I'm going to try it.
How much water and what enzymes and how much did you use?
Re: Whisky mash
Posted: Wed Jan 22, 2014 7:20 pm
by Horsecreek shine
I suppose your right ya ya
This is usually a 5 gal wash to keep up the og
And I've also used dextrose "corn sugar" sometimes called different at shops
I've used a lil oat malt in it gives it more complexity or some hard red wheat depending on taste
I've used for yeast is the Whisky pure 12% and it has a lot of esters with the combination almost a apple / raspberry smell it interesting
I've also used turbo and it's not bad
On this next round I'm going to try wlp001 California ale 1 it's supposed to be a real good wisky yeast
I'd like to know how yours turns out
Thanks much
Horsecreek
Re: Whisky mash
Posted: Wed Jan 22, 2014 7:23 pm
by Horsecreek shine
Amylase enzyme is generally what I use with dap and yeast nutrient especially when I make a yeast starter
Horsecreek
