All Spirits Run
GaMountainMan
All Spirits Run
Post by GaMountainMan »
I have been saving up for an all spirits run. I have a 6 gallon boiler and was just wondering how much I must have to do an all spirits run?
Anything worth doing is worth over doing.
toast860
Re: All Spirits Run
Post by toast860 »
depends on how you heat it. if it electric then enough to cover the element. if not then it don't matter . I would wait till I had like 4 gallons. imo. remember to cut to 40%
if you cant build a paper airplane, then leave the rocket alone.
its like wiping before you poop, dont make sense.
GaMountainMan
Re: All Spirits Run
Thanks. I was just thinking the less you put in there the more space you would have in pot for the vapor to have to fill so was thinking that perhaps there was a point to where you would be wasting it. Thanks again!
ga flatwoods
Re: All Spirits Run
Post by ga flatwoods »
How much will you have when cut to 40% or under?? I would look for about 4.5 gallon max.
I am still kicking.
Ga Flatwoods
GaMountainMan
Re: All Spirits Run
Probably around 3 gallons. Im going to do a couple more runs and just get it up to around 4.5 gallons. Im in no rush =) thanks all.
