heating elements from mile hi
mightymini
Post by mightymini »
Anyone have any experience with these?
http://www.milehidistilling.com/heater- ... 500w-115v/" onclick="window.open(this.href);return false;" rel="nofollow
Buiding my 2" Boka with a 1/4 keg stainless boiler. I am chasing my tail trying to select a heating system and this seems too easy.
Any input welcome!
aj2456
Re: heating elements from mile hi
Post by aj2456 »
i read from someone else's posting that these as they have a thermostat are a bit on/off
ie not so hot for what we are after, made sense to me
Q: What do you call a scotsman thats given up drinking?
A: Dead
FreeMountainHermit
Post by FreeMountainHermit »
mightymini wrote:Anyone have any experience with these?
No need to reinvent the wheel. The water heater elements that many here run just flat out work and are cheap to replace if the occasion arises. The controllers can be daunting for those not having the understanding or desire to build one but the upside is that there are reliable sources out there to buy from.
FMH.
Last edited by FreeMountainHermit on Sun Jan 26, 2014 3:31 am, edited 1 time in total.
Blah, blah, blah,........
jholmz
Post by jholmz »
heres a link to a post about that element looks like its not very good as its thermostaticly controlled and will cycle on you http://homedistiller.org/forum/viewtopi ... r#p7041376
Hawkeye3
Post by Hawkeye3 »
Welcome MightyMini. Good advice from the above posts. A basic hot water heater element ($12.00) and some sort of voltage controller is the way to go. I use a router speed controller. Not the best but workable.
PSIIHC and lovin' it.
"The Ultimate Result of Protecting Men From The Acts Of Folly Is To Fill The World With Fools" ...Herbert Spencer
mightymini
Thanks to everyone for the advice. Think I knew the answer before i posted. Think i will stick with the internal heater just a little nervous about running it flat out. I remember reading something about the router contoller. Is there a post with a diagram of your set up? Thanks again everyone!
snooka
Post by snooka »
Harbor freight $15.00 and add a heatsink to it. Lots of threads on here about it.
Bob Loblaw
Post by Bob Loblaw »
For temperature control, go to stilldragon.com, order their DIY kit. It is $31 + shipping. All you add is your labor and some 10/3 wire. It's rated for 40A/220V so it is future proofed. I just posted pics of the finished product here: http://homedistiller.org/forum/viewtopi ... 0#p7145900
While you are at it, I would suggest geting their element guard kit. Gives a neat (and SAFE!) connection to a 2" stainless ferrule welded into a keg. Ferrule cost maybe $6 and you can get the welding done for less than $50.
