Page 1 of 2
fermenting vessels
Posted: Mon Jan 27, 2014 5:53 pm
by sunshine1101
did some searching on the site for this answer and didn't see what i needed. i am upgrading to a single 30 gallon fermenter and found a "food grade" barrel. i inquired about the composition of the barrel and they didnt have any info other than it was use to ship pharmaceuticals that were enclosed in bags in the containers. i asked and there are not stamps of labels on the barrels stating the composition. the barrel is blue with a snap ring lid. is there anyway to tell if this material will leach ?
Re: fermenting vessels
Posted: Mon Jan 27, 2014 6:05 pm
by bellybuster
you say it is food grade....
probably HDPE, there should be some searchable markings on the bottom.
edit... more than likely medium density poly ethylene.
Posted: Mon Jan 27, 2014 6:15 pm
by sunshine1101
heres something off another similar barrel does this verify anything?
Posted: Mon Jan 27, 2014 6:21 pm
by acfixer69
Yup they are both blue
AC
Posted: Mon Jan 27, 2014 6:25 pm
by ga flatwoods
I can tell you one thing for sure and that is lose the lock ring and just put the lid on the barrel unlocked. I did that without thinking about it and it damn near knocked me out when the ring was loosened! LOL @ME!
Posted: Mon Jan 27, 2014 6:28 pm
by sunshine1101
Even with an airlock ga flatwood? Where you at in ga? Im in the south east
by Cardinalbags
Not 100% sure but looks like polypropylene. If it is I would have no concerns using as a fermenter vessel.
Posted: Mon Jan 27, 2014 6:30 pm
by sunshine1101
Ive inquired about better pics of the bottom to try and verify
Posted: Mon Jan 27, 2014 6:34 pm
by ga flatwoods
Use no airlock. Pm me sunshine.
Posted: Tue Jan 28, 2014 6:09 am
by sunshine1101
Guy said it is pp....... thanks for the info fellas
Posted: Tue Jan 28, 2014 6:36 am
by bellybuster
just for interest, did a bit of research on "Food Grade" and "Food Safe".
Food Grade is safe for long term storage of edibles and "should be clearly marked on the container by etching, moulding or engraving. If not the words "Food Grade" the material the bucket is made of must be labelled. I checked out my buckets that are sold as fermenters and they are labelled as HDPE. If you look that up it is indeed Food Grade. HDPE has the recycling symbol of 2
"Food Safe" is safe for short term contact with edibles and is not necessary to be labelled as such. I cannot find a definition of "short term"
The markings on the bottom of the above barrel can be looked up here
http://www.usplastic.com/knowledgebase/ ... entkey=743
As you can see it really doesn't tell you much at all.
There should be a recycling number on it inside a triangle. As said above HDPE is a 2. PP is a 5.
From what I can find, both HDPE and PP are indeed food grade.
I'm bored this morning, -25 and windy outside. Putting off clearing the driveway
Posted: Tue Jan 28, 2014 9:11 am
by Jimbo
ga flatwoods wrote:I can tell you one thing for sure and that is lose the lock ring and just put the lid on the barrel unlocked. I did that without thinking about it and it damn near knocked me out when the ring was loosened! LOL @ME!
LOL, man youre full of storys about pressurized vessels Flatwoods!
Posted: Tue Jan 28, 2014 9:41 am
by FreeMountainHermit
sunshine1101 wrote:Even with an airlock ga flatwood? Where you at in ga? Im in the south east
Ga.Flatwoods lives in the swamp with the critters.
FMH.
Posted: Tue Jan 28, 2014 11:52 am
by ga flatwoods
Nope FMH the Flatwoods are a little higher than the swamp!
Ga Flatwoods
Posted: Tue Jan 28, 2014 6:38 pm
by sunshine1101
http://en.wikipedia.org/wiki/Recycling_codes" onclick="window.open(this.href);return false;" rel="nofollow
this is helpful in translating the codes on the plastic containers.
Posted: Thu Jan 30, 2014 5:46 pm
by sunshine1101
related to this thread... i am saving up stripping runs of ujssm and ran out of gallon glass jars. i have several polypropylene food grade buckets. i know polypropylene is safe for the low alcohol content of the mash but is it safe to store 110 proof liquor? if not what is common practice to collect stripping runs until you are ready to do a spirit run other than glass carboys....
Posted: Thu Jan 30, 2014 7:49 pm
by plaztikjezuz
You could always line the container with a large food grade 5 mil or thicker plastic bag.
This also makes clean up a cinch...
Just don't rip the bag!
Posted: Fri Jan 31, 2014 3:44 am
by bellybuster
Glass or stainless is your best bet. Food grade does not mean alcohol grade.
Posted: Fri Jan 31, 2014 9:18 am
by ga flatwoods
Used stainless steel cornet kegs are your best friends.
GA Flatwoods
Posted: Mon Feb 03, 2014 1:27 pm
by Deezil
plastic carboys ok? I have 3 for a water machine that Im not using for water.
Posted: Mon Feb 03, 2014 1:37 pm
by Prairiepiss
Deezil wrote:plastic carboys ok? I have 3 for a water machine that Im not using for water.
For fermenting yes.
Posted: Mon Feb 03, 2014 2:34 pm
by ga flatwoods
PP I used a plastic water carboy once to make wine in. Big mistake unless you like huffing pvc glue be ause it is sure what the wine tasted like. That in glass was fine. Never used another for fermenting or storage, toting water maybe.
GA Flatwoods
Posted: Mon Feb 03, 2014 2:42 pm
by Jimbo
Flatwoods, what the hell is that avatar, looks like a bloody skull? Hopefully not a selfie after the last bender on Jackass Juice?
I think them clear water bottles are PVC, and the blue and white food safe fermenters we all use are PolyEthylene.
I know the online brewing supply houses are selling them for beer. But that might just be economics and infinitely easier shipping than them heavy fragile glass carboys
Posted: Mon Feb 03, 2014 2:59 pm
by Deezil
ok, I have a couple glass carboys also, but was just asking for simplicity sake as I have more of the plastic ones. Thank you.
Posted: Wed Feb 05, 2014 1:08 pm
by blaze379
I have used these for years. I have sizes ranging from 15 gal to 60 gal. Anyone else used these?
Posted: Wed Feb 05, 2014 1:32 pm
by bellybuster
I've been looking at those for quite some time but what you can buy for $59-70 will cost me $150-200 here in Canada. Pisses me off.
Is that the Ace tanks?
Posted: Wed Feb 05, 2014 1:55 pm
by blaze379
I actually found them local to me, so I don't pay much in the way of shipping..... still almost $200 for a 60 Gallon.
Posted: Wed Feb 05, 2014 2:27 pm
by acfixer69
blaze379 wrote:I have used these for years. I have sizes ranging from 15 gal to 60 gal. Anyone else used these?
Yes I have 2 - 30 gal the I set in 55 gal steel drums with access doors to operate valves and casters for mobility in the brew room.
@ BB mine are Ace but the price has gone up in the states. I looked to buy one more and was shocked at the current price.
AC
Posted: Wed Feb 05, 2014 3:17 pm
by bellybuster
http://www.spraysmarter.com/ace-roto-mo ... allon.html
This is the one I'd like but it is over $200 in Canada. I have a buddy in NY that comes up for work in the spring, may get him to bring me one
Posted: Wed Feb 05, 2014 3:36 pm
by Cardinalbags
I bought two of the 30 gallon HDPE barrels complete with locking lids from Uline. $89 CDN each plus shipping. I think it was landed at my door for $200 total for the two.
