Column packing denisty?
HyperandDrunk
Post by HyperandDrunk »
Hi there.
My VM still packing is approximately 150cm tall and filled with copper mash.
It produces super pure 95-96% but it is doing so rather slowly. (1-2 drops a seccond)
I was wondering if I added even more copper and compressed it to fit the column if that would make it produce 95% faster due to a larger surface area?
Thanks.
ga flatwoods
Re: Column packing denisty?
Post by ga flatwoods »
You are close to the limits of your ability now. It can be added as long as you can breath through it . It may be something to try as well as removing some of what you have there now.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
What is the diameter of your column as that relates to speed!
HyperandDrunk
Will try. Thanks!
Diameter is 2.5" stainless
T-Pee
Post by T-Pee »
When ya breath through it, do you go "WHOOO" or "whhhhh" The latter will normally be a better packing density.
tp (thoroughly descriptive)
Probably should be a bit faster, I had a 2" VM and with a 10 gallon charge it took me 12-15 hours to run. With my 4" CM I can do an 11 gallon charge in 3-4 hours with similar purity.
HyperandDrunk
T-Pee wrote:When ya breath through it, do you go "WHOOO" or "whhhhh" The latter will normally be a better packing density.
Haha, probably the latter.
I will try to pack it harder and add some more to check if that will make it faster.
Hound Dog
Post by Hound Dog »
:lol: :thumbup: I love the description!
Using Google Search
clearspirits
Post by clearspirits »
A big question concerning your flow is: How much power/energy are you putting to the boiler?
Your column may be able to maintain that level of purity with a faster flow. I find with my CM column that after I dial in the cooling flow to the dephlagmator, product flow is controlled with power to the boiler. 92-95% with a quart in 25 or so minutes is very possible.
Hound Dog
Post by Hound Dog »
I can pull a quart in 15 minutes at 96% with my 3". As for power input, bout half on my burner. Way less power since I reduced the size of my lava rock thereby increasing the density of my packing.
Using Google Search
