my pot and thumper
jedneck
my pot and thumper
Post by jedneck »
Here is my pot and thumper setup. It is a 1/2 keg feeding a 6 gallon bucket milker for a thumper. The thumper supply line is one inch feeding in the side of thumper(less copper that way). Column is one inch also. Not sure on length I started at a height that will clear a quart jar and worked backwards. Condenser is a triple wall leibig. 1/2 od inside 1 inch inside 1 1/4 inch. Vapor path is between 1 inch and 1/2 inch. Overall cooling length is about 18 inches. And the head can be rotated to the other side to collect into a six gallon carboy for strip runs. Time to go buy vinegar to clean her.
big help
Dunder
This topic has 11 more replies
Register Login
