Why malt corn?
touchmydrumset
Why malt corn?
Post by touchmydrumset »
This is my first post outside of the welcome center, so I hope I dont sound like a complete bone head.
From what I understand, malting grain is done to release the enzymes required to convert starches to sugar. Also, corn does have possess these enzymes.
So, why malt corn? Why not just add malted barely to gellentanized corn?
I hope I did not miss use the term malt, as I am under the notion that it is simply grain that has begun to sprout and stopped once the enzymes have been released.
bellybuster
Re: Why malt corn?
Post by bellybuster »
Malted corn allows you to do an all corn mash without using liquid or powdered enzymes
MichiganCornhusker
Re: Why malt corn?
Post by MichiganCornhusker »
You are using the term correctly.
You're right, you don't need to malt corn to make whiskey. Adding malted barley to gellatinized corn will do the job of mashing just fine.
But, sometimes you might want to make a recipe without barley, or maybe just don't want the expense of buying malted barley. That's where malting corn comes in.
Besides, malting corn can be a very rewarding process in itself!
Corn malt also produces a whiskey with a different flavor than non-malted corn. You can make good whiskey with a variety of malted grains for sources of enzymes, or you can even use liquid enzymes.
edit: posted while bellybuster was posting
touchmydrumset
Re: Why malt corn?
I had read that malted corn does not have the enzymes. is that incorrect?
touchmydrumset
Re: Why malt corn?
ok, so malting the corn is not for releasing enzymes(thats arent present anyways). its to release the starches?
Re: Why malt corn?
touchmydrumset wrote:I had read that malted corn does not have the enzymes. is that incorrect?
Malted corn has enzymes, but less than barley.
Malted Barley has enough enzymes to convert several times it's weight.
Malted corn can only convert itself.
MichiganCornhusker
Re: Why malt corn?
touchmydrumset wrote:ok, so malting the corn is not for releasing enzymes(thats arent present anyways). its to release the starches?
The malting process doesn't really "release" enzymes. In any grain including corn, malting develops enzymes. Unmalted grains don't contain enzymes and don't have any ability to convert starches to sugars.
Re: Why malt corn?
No
MichiganCornhusker
Re: Why malt corn?
Malted corn does have enzymes.
As Shadylane points out, malted corn has less power to convert starches than malted barley, but it does contain enzymes. Research Diastatic Power to learn how various grains can contribute enzymes to the mash.
touchmydrumset
Re: Why malt corn?
I understand. Thank yall for this information i really appreciate it.
I was a little cloudy on this subject. now i realize i need to spend some more time researching how grains develope
touchmydrumset
Re: Why malt corn?
Thanks for the Diastatic Power advice. a quick search and i have found a lot of information. this will come in handy
MichiganCornhusker
Re: Why malt corn?
touchmydrumset wrote:I understand. Thank yall for this information i really appreciate it.
It will be very rewarding research, malting and enzymes are two of the most fundamental pieces of magic in the whole process! Good luck. :D
touchmydrumset
Re: Why malt corn?
I agree. its a fascinating topic. i will learn a great deal with this
touchmydrumset
Re: Why malt corn?
Wow. I had no idea malts are measured in a degree *L.
the more i read the more excited i get to get my own operation running
bellybuster
Re: Why malt corn?
Keep in mind though that corn needs to be gelatinized and that kind of heat will denature the enzymes. More research...haha
MichiganCornhusker
Re: Why malt corn?
bellybuster wrote:Keep in mind though that corn needs to be gelatinized and that kind of heat will denature the enzymes. More research...haha
Another reason to malt corn: As I understand it, the malting process frees up the starches in the corn so that high temp cooking is not required for corn that has been malted.
Indeed, as bellybuster says, high temps will destroy the enzymes created by malting. So, corn malt does not need to be gelatinized, but rather gets mashed at temps between 140F-150F, no higher.
bellybuster
Re: Why malt corn?
And I learn something new as well, thanks
Red Rim
Re: Why malt corn?
Post by Red Rim »
I just walked in from grinding up my malted corn. Kind of a pita! I think I let it go a day too long and now I smell like vomit. Oh well, part of the journey!
Hell, how do you beat getting seeds to sprout and then grinding them up and turning them into whiskey!
Halfbaked
Re: Why malt corn?
Post by Halfbaked »
Woodshed says his malted corn in a 30% malt corn-70% cracked corn ratio has no problems in conversion.
touchmydrumset
Re: Why malt corn?
yall guys have helped me learn alot in this short time. thanks alot!
will continue researching and will let you guys know when i get my own mash working.
woodshed
Re: Why malt corn?
Post by woodshed »
Properly malted corn will convert more than itself given an unmalted grain that has been gelatinized properly.
Matled corn should go in 150f or lower. I go in at 152 which drops me to 148 after stir in. Perfect.
RockinRockies
Re: Why malt corn?
Post by RockinRockies »
What is the flavor profile? Last time I malted half my yellow dent, it tasted like buttered popcorn.
I just ordered a 50# sack of blue corn and we considering malting half
Re: Why malt corn?
touchmydrumset wrote: Sun Nov 23, 2014 4:21 pm
Folks around here are often into experimentation.
We do things like malting and are even known to use store bought enzymes. :oops:
Re: Why malt corn?
From my experience malted grains smell, taste and give a differently flavored end product to those that are unmalted.
Seems like a good enough reason to me.
Re: Why malt corn?
Saltbush Bill wrote: Sat Jul 15, 2023 1:57 am From my experience malted grains smell, taste and give a differently flavored end product to those that are unmalted.
+1.
RockinRockies
Re: Why malt corn?
I should be more specific. Half the grain bill was miles, cracked yellow dent, and the other half I malted. I used a mix of red star DADY and bakers yeast. I did booners casual process. The end product was cut very tight and tasted like jelly belly popcorn jelly beans, but more authentic. It was like drinking buttered popcorn. Very one dimensional but really delicious.
So, do you folks think that's a lucky flavor from a bad fermentation or maybe that's the flavor profile malted corn provides?
And, why would malted corn overtake the blue (ordered yesterday) and blood red corn, of which I just ordered a 50# sack
Re: Why malt corn?
RockinRockies wrote: Sat Jul 15, 2023 7:51 am… So, do you folks think that's a lucky flavor from a bad fermentation or maybe that's the flavor profile malted corn provides?
A little of both!
Corn imparts a “sweet flavor” and malted corn makes it taste a little “creamy”. But, a “buttered popcorn” flavor would be in part due to diacetyl formation during fermentation.
Yeast selection and fermentation (aggressiveness) affect diacetyl production. Lager yeasts can be more apt to make it than most ale yeasts. And the diacetyl (in a lager) can be reduced by raising ferment temperature after latent fermentation. The warmer temperature will trigger the yeast to reduce it.
If your product was just “the beer”, then the buttery quality would be a detractor. But, when combined with the “corny sweetness” in a distiller’s beer, it can produce the flavors you noticed in your spirits, especially when aged properly on some toasted American white oak. The key, however, is “balance”. Too much hot buttered popcorn can be overwhelming. But, it certainly will give your products a “signature”.
Red and blue corn do indeed have a different flavor profile than yellow dent. But the characteristics are mild and depending on the proportions in the grainbill, the contributions may be un-discernible. YMMV.
RockinRockies
Re: Why malt corn?
Hmm, thank you for your input. Sounds like I need to just malt a mash separate, and then add the red and blue together in one batch with enzymes
I'm almost derailing the thread now and I don't want to get off topic from malting. Thanks everyone
Re: Why malt corn?
Another reason is malting makes proteins and nutrients that yeast likes. :ewink:
tommysb
Re: Why malt corn?
Post by tommysb »
RockinRockies wrote: Sat Jul 15, 2023 9:32 am Hmm, thank you for your input. Sounds like I need to just malt a mash separate, and then add the red and blue together in one batch with enzymes
FWIW - I've had the buttered popcorn flavour present in all corn - both with RED and normal feed corn. That's fermented with bakers' yeast. I always assumed it was from the corn, rather than diacetyl produced in fermentation. I have done similar ferments with a mixture of corn, barley and wheat, and had less buttery tastes. Of course, nutrients in the barley and wheat might also affect yeast fermentation behaviour too.
