Here making ethanol for your own use is allowed, but selling it is forbidden.
My plan is to disseminate very cheap ethanol stills around and supply my neighbors with cane mash. This is legal.
This is interesting for my neighbors as the ethanol will cost between 33 to 50% less that way. And 90% of the cars sold today in Brazil are Flex.
My point is to gather your opinions about my still project, made out of scrap material, mainly steel. No copper at all.
I will use a 200Litres steel barrel like everyone knows as a boiler:
Under this barrel I will fix a steel plate so that the barrel can bear the high temperatures of dried cane fibre direct fire.
On the top I will put a 2" column full of SS scubbers until the condenser which will use a automotive radiator like this:
This radiator avoids me to buy any copper (for a serpentine) and is quite efficient.
The radiator will be in a sealed steel box where the vapors coming from the column will circulate, and condensate.
Some of the liquid will go back to the column and some will be collected, like the Bokabob two cup fractionating still, depending on what %ABV is collected.
Let's get to the point: I will have 150 liters wash boiling in the barrel on one side and on the other side I have a very effective condenser. My questions are:
- what is the ideal height of the 2" column to collect pure ethanol in these conditions?
- Keeping in mind the volume of mash boiling, would you use a 3" column instead? If yes, what would be the ideal height?
- For those who already made some similar experiments, what is the average time necessary to collect the +/-17 litres of 85% ABV out of 150 liters of wash at 10%ABV?
- Eventhough the process is quite simple for the operator, what would you do to make it more simple?
No doubt that the still has a limited life, especially the boiler, but I will provide my neighbors with plans to repair it and to better it. My aim is to give them the opportunity to make their first shots.
