Page 1 of 2
HELP
Posted: Wed Nov 21, 2007 7:57 pm
by nv_hunter
I am distilling now and this is the color of it. What could be wrong?
Posted: Wed Nov 21, 2007 7:58 pm
by nv_hunter
Oh and its a grain whiskey wash.
Posted: Wed Nov 21, 2007 8:02 pm
by Husker
Very likely you are running too fast, and have TOO much wash in the boiler of your still, and are boiling over.
H.
Posted: Wed Nov 21, 2007 8:06 pm
by Ricky
show us a pic of your still. could help answer your question
Posted: Wed Nov 21, 2007 8:07 pm
by Husker
What is the rod behind the glass. The one with the blower on top?
H.
Posted: Wed Nov 21, 2007 8:08 pm
by Ricky
also show us a pic of the car in the background. put it in the off topic. love them muscle cars
by As-Ol-Joe
That is what mine looks like at the end of a run after I turn the heat up. From the spashing on the sides, I would say your pot is to full.
Posted: Wed Nov 21, 2007 8:09 pm
by nv_hunter
Pics are on the way. The temp is 202 f and holding.
Posted: Wed Nov 21, 2007 8:10 pm
by Husker
I think the still is in the pic (part of it).
Is this a new still (is this its maiden run?) If so, and you have not cleaned it, then looks like you are cleaning it out now. This kind of crud is left from the manufacturing process (soldering flux, etc).
On a new still, you need to do a water only run (or a couple), then possibly do a run using a box of cheap crappy wine (or a cheap sugar wash) to clean it out and "prime" it for running good mashes through.
H.
Posted: Wed Nov 21, 2007 8:13 pm
by nv_hunter
Yeah this is a new still. I tasted the product and it doesnt have any bite at all. No flash at all iether. Here is the still.
Posted: Wed Nov 21, 2007 8:15 pm
by nv_hunter
Oh and I had only 3 inchs or so in the keg.
Posted: Wed Nov 21, 2007 8:16 pm
by Husker
nv_hunter wrote:Yeah this is a new still. I tasted the product and it doesnt have any bite at all. No flash at all iether. Here is the still.
is this a fermented grain whiskey run? No flash meaning you cant light it? Sounds like there might have been no ethanol in the mash.
If this is a new still, it is likely that you are simply getting gunk out of the still cleaned out by this run.
H.
by Ricky
is that a chevelle?
Posted: Wed Nov 21, 2007 8:17 pm
by Ricky
the bar stool is cool too
by Husker
Also, are you sure your condenser is not leaking?
H.
Posted: Wed Nov 21, 2007 8:18 pm
by Ricky
as for the still what husker has said. the still looks good. not enough mash to boil over. must just be dirty.
Posted: Wed Nov 21, 2007 8:26 pm
by nv_hunter
How long does it need to clear up? Im at about 1 1/2 litres now. Also I posted the chevelle pics in the off topic room.
Posted: Wed Nov 21, 2007 8:29 pm
by Husker
nv_hunter wrote:How long does it need to clear up? Im at about 1 1/2 litres now. Also I posted the chevelle pics in the off topic room.
I would do a run of 5 gallons (at least) of water. The water vapor will help clean it out. Then run a cheap sugar wash (or dirt cheap wine). I would recommend running the wine, then putting all of it (the distillate, and what was in the boiler) back in the boiler and running it again.
That will help clean the crud.
However, you mentioned that you got no "flash". If you were meaning "fire" on the output, then either:
1. you have no EtOH in the wash to start with.
2. your condenser is leaking (thus watering down the distillate coming out).
H.
Posted: Wed Nov 21, 2007 8:35 pm
by nv_hunter
I dont think its leaking because the water was running befor I started the boiler and nothing came out. Here is the recipe I used, Maybe it wasnt fermented enough.
SWEET FEED MOONSHINE # 5 gallon bucket of sweet feed (Sweet feed has several different grains and molasses making it a great tasting whiskey.) one package of yeast (using distillers yeast will increase quality and quantity) # 5 pounds sugar # water Put enough feed to cover bottom of 5 gallon bucket a good 4 inches deep Add 5 pounds of sugar. Fill 1/2 full with boiling water. Mix until sugar is dissolved. Let it set for 90 minutes and then finish filling with cool water. Add the yeast after it has cooled to the recomended temperture on the yeast label. Cover with lid--our lid has a little cap that screws on, leave it loose to breathe. 4-5 days later it's ready to run! This is an old-timer recipe and works quite well. My liquor is always 150-180 proof. I don't recommend this for pot stills unless you filter it by pouring it through a pillow case into a 5 gallon bucket after it has finished fermenting. Otherwise the meal will settle and burn in the bottom of your still. Some folks leave the solids in the pillow case and tie it off where it will not touch the bottom of the still.
Posted: Wed Nov 21, 2007 8:36 pm
by nv_hunter
I used wyeast mead yeast. Is it the yeast maybe?
Posted: Wed Nov 21, 2007 8:37 pm
by Husker
did you remove the grain or did you distill "on the grain"?
Posted: Wed Nov 21, 2007 8:39 pm
by nv_hunter
I ran it through a pillow case first.
Posted: Wed Nov 21, 2007 8:43 pm
by Husker
nv_hunter wrote:I ran it through a pillow case first.
I bet the color is from the dirty still. As for the lack of EtOH, that is more puzzling, unless there was no EtOH in there. Could be that you pitched your yeast when it was too hot, and killed the yeast. If you did that, there will be no ethanol.
Taste the wash. Is it sweet? A finished mash should taste like cheap wine (well sort of at least).
Is it vinegar?
Did it smell like fresh yeasty bread (or something yeasty) while working?
Did it bubble a lot?
H.
Posted: Wed Nov 21, 2007 8:48 pm
by nv_hunter
It did bubble alot. It was still bubbleing when I filtered it. It said to let it ferment for 5 days but I am wondering if it wasnt enough. It did taste sweet. The distilant smells and tastes sweet even after it has been destilled.
Posted: Wed Nov 21, 2007 9:11 pm
by nv_hunter
Im 4 litres in now and it has a blue tint to it.
Posted: Wed Nov 21, 2007 9:20 pm
by nv_hunter
here is a pic of the last bottle full.
Posted: Wed Nov 21, 2007 9:31 pm
by As-Ol-Joe
That looks like mine does when I get close to the boiling point. Where I live the boiling point is 208f.
Posted: Wed Nov 21, 2007 9:42 pm
by nv_hunter
208 at the top of the column or 208 at the pot?
Posted: Wed Nov 21, 2007 9:47 pm
by As-Ol-Joe
What temperature was it when you started taking off?
Posted: Wed Nov 21, 2007 9:49 pm
by nv_hunter
Its been stuck on 202.5 the whole time.
