A question of design understanding.
yakattack
Post by yakattack »
OK.
I want to make sure that I am understanding what I am reading and can proceed safely with my build.
I am upgrading slightly from my 2 gallon ss pot set up with a worm in a bucket to a 12 gallon boiler with a lieburg (sp?).
I haven't figured out any demintions because I need a clarification of a point. I understand the scientific principal of how it works to knock down the vapors. But what I am unclear about is configuration.
Is there a significant difference between having a coil inside the jacket or is a straight pipe sufficient to have enough heat transfer to knock the vapor down ?
I will be using 2 inch from the boiler to the 90,after the 90 reduce to 3/4 or 1/2 inch. I will be running the leiburg at about a 45* angle aiming for about a foot and a half away from from the boiler. Burner is a 60, 000 but propane burner. I'll be running a continuous circulation pump system for cooling as I run in the garage.
I understand the need for turbulence both in the vapor path and in the coolant path.
As a matter of design, I considering instead of using wire wrapped around the straight making my own copper heat sink fins to solder around the pipe ( think fan blades) for two reasons. One this should help pull off the heat more efficiently ( conduction) and also cause some decent turbulance in the coolant water through obstruction and the curved blades.
I would love to do a design picture but do not have access to a computer and am just on my smart phone.
I will be able to do a mock up for final inspection prior to building it. Just am looking for input on the ideas.
And if I am way off base please correct me and point me to some further reading to correct.
I await your expertise..
Yak
cranky
Re: A question of design understanding.
Post by cranky »
I don't know if you can call what I have "expertise" but I do have a 15.5 gallon keg and use 1.5" copper pipe reduced to 1/2 into a 32" (?) liebig. I used the spiral wrap of #12 wire for a turbulator and another one inside the 1/2 inch and I can do a stripping run at a qt every 4.5 minutes so I don't really see any reason to redesign anything that works so effectively.
yakattack
Post by yakattack »
cranky wrote:I don't know if you can call what I have "expertise" but I do have a 15.5 gallon keg and use 1.5" copper pipe reduced to 1/2 into a 32" (?) liebig. I used the spiral wrap of #12 wire for a turbulator and another one inside the 1/2 inch and I can do a stripping run at a qt every 4.5 minutes so I don't really see any reason to redesign anything that works so effectively.
Do you have a design sketch? Or one you recommend? Is your vapor pipe straight or coiled?
thatguy1313
Post by thatguy1313 »
Straight vapor pipe us a Liebig. Coiled is a grahm. Samohan has some good sketches if each.
bellybuster
Post by bellybuster »
Anything flammable a foot and a half from a propane burner is asking for trouble
cranky
Post by cranky »
I did the same thing as npstephe on this thread http://homedistiller.org/forum/viewtopi ... 16&t=51787 and made the liebig just like hookline in this thread. http://homedistiller.org/forum/viewtopi ... =87&t=9247
cranky
Post by cranky »
bellybuster wrote:Anything flammable a foot and a half from a propane burner is asking for trouble
Nice catch bellybuster, I missed that. My liebig is at a 45 degree angle and even though I'm all electric the end is roughly 3 feet from the boiler.
yakattack
Post by yakattack »
Understood. Will make sure my take off is farther away
ShineRunnah
Post by ShineRunnah »
You're thinking far too much about this condenser. It just doesn't need to be that complicated to be extremely effective.
The wire around the pipe inside the water jacket is sufficient for turbulence, and something as simple as a copper scrubby loosely tucked into the vapor path will do just fine.
As for length, I've not seen anyone have issues from a condenser being too long, its always those running the short liebigs that seem to have issue.
My liebig on my 15gal keg is 36"+ long 3/4" copper with a PVC sleeve. I don't have issues under normal use, and I barely need any water flow.
Keep it simple. If you want to get fancy, build a shotgun condenser. The beauty of a liebig is its utterly simple yet works so damn well.
rager
Post by rager »
ShineRunnah wrote: The beauty of a liebig is its utterly simple yet works so damn well.
and it looks like a scrape piece of pipe just laying around :shock:
3/4 over 1/2 and about 36inchs long seems to be the minimum of what people are using. but are using with success.
thatguy1313
Mine is bout 40" 3/4 over 1/2. No issues at all. Copper wire wrapped around the 1/2" and scrubbie inside.
cranky
Post by cranky »
I just measured mine 36" of jacketed section. works real nice.
myles
Post by myles »
All condensers should be designed to cope with the maximum power available in the boiler.
size and physical dimensions are personal choice - within a range determined by boiler power, coolant flow rate, coolant temp and several other factors.
Each condenser can thus opperate over a range of boiler powers by adjusting other parameters.
For many the overall size of the condenser is a matter of convenience in use. A big reason some folks change to a tube and shell design is because it can be a bit shorter. This makes it more user friendly.
I have 1 liebig that is over 7 foot long, but I coiled it to take up a cubic foot of space to make it more convenient to use.
Start with considering the power and work on from there.
Shine NOLA
Post by Shine NOLA »
I would like to see a picture of that Myles......
sounds cool
for everything bad, whiskey; for everything good, the same
yakattack
Post by yakattack »
Agreed. A pic would be sweet
rager
Post by rager »
sounds cool
+2
