Activated Carbon
firefly
Activated Carbon
Post by firefly »
I have a few liters of neutral spirit that I would like to filter and im ready for my 1st try....I read the Gert Strand book and I just wanna make sure I understood what I read....
I have the kit that came from brewhaus....
1)boil and clean 4-5 times etc...
2)put the filters at the end and fill tube with warm water
3)Fill tube with the carbon
4)Pour more water through the tube and wait till all the water comes out
5)and now I pour my spirit and let it go....
After pouring my spirit....can I let it work alone or must I keep an eye on it.....
Also read that I should not do this in a cold place correct??
AfricaUnite
Re: Activated Carbon
Post by AfricaUnite »
firefly wrote:I have a few liters of neutral spirit that I would like to filter and im ready for my 1st try....I read the Gert Strand book and I just wanna make sure I understood what I read....
1- Maybe the first time you get the carbon, I think 4-5X is excessive. I'd say 3x max the first time. I only ever do it once or twice in between runs. And by clean I assume you mean put it in the oven.
2-The filters go at the bottom of the tube and there should be a piece of plastic with holes in it that goes on top of the filter paper. Then you screw that bottom piece in.
3-Yep
4-Yeah fill up the funnel with water at least once, if the carbons already wet thats in the tube (kind of a pain to get in this way) then one 5L funnels worth should do you. If the carbons dry I would run at least 2 5L funnels full of water through.
5- Pour the spirit in while theres still a bit of water visable in the funnel, you dont want any air gaps. you will get some dilution but when your tasting the water/vodka cut off your going to take about 500ML of weak vodka out, just redistill it.
6- Make sure you flush out with 2L of water, same deal your going to get very watery vodka at the end, save and redistill.
firefly
Post by firefly »
AfricaUnite, thanks....wasn't sure if I had to let all the water out before pouring in the spirit.....thanks cause I was just about to do it the wrong way.....cheers
. :D
Uncle Jesse
Site Admin
hmmm
Post by Uncle Jesse »
Do I understand right, you're using carbon-filled, plastic containers for this? Or am I reading incorrectly? I'm a bit nervous lately when I see the name Gert Strand.
firefly
Post by firefly »
Uncle Jesse, you have me worried now....this is the item im referring to
http://www.brewhaus.com/Filter_Unit_p/40002100.htm" onclick="window.open(this.href);return false;" rel="nofollow
It is a chemical tolerant plastic....isn't this what most people use???
P.S: It says to pour the carbon into the tube that is already filled with water.....
Uncle Jesse
Site Admin
hmmm
I don't know, I've never used carbon before as I've never made neutral spirits.
Chemist is the one to ask. As he's stated, some plastics rated for alcohol in the U.S. won't handle higher proof alcohol very well.
firefly
Post by firefly »
:D I'll wait to see if Chemist comes to the novice section....
As for me...it will be my 1st time and my spirit will be diluted to 40% before I pour it in the tube.....
I guess i'll wait a little while ....no hurry....
thanks Uncle Jesse...
Husker
Re: hmmm
Post by Husker »
Uncle Jesse wrote:I don't know, I've never used carbon before as I've never made neutral spirits.
The "instructions" about carbon filtering are not for high proof. Most instructions I have seen, start out by watering the booze down to 80 proof or so. I think at that level, there are probably more plastics that are ethanol tolerant. However, since I am pretty much ignorant on the chemical composition of plastics, I would not know which of the plastics would be safe for cool 40% and which would still be unsafe.
NOTE from the brewhaus page, even the funnel is plastic. I find the DIY method to be better solution, than the commerial prefab stuff. With DIY, you can control what you have. You could easily build a carbon filtering system out of 2" copper. I myself would rather just do a better job of distilling, and scrap the carbon filtering altogether.
H.
firefly
Post by firefly »
:D ...Thanks Husker...as a noob...I gotta learn the hard and $$$$expensive way$$$$.....I just bought the whole kit......and was ready to go....
I hope they wouldnt sell something that was unsafe.....and my spirit is 40% so I guess I should be ok...
P.S: In my part of town...we calculate alcohol as a %
As I can see, people down south refer to it as "proof"
Is there a conversion chart on the mother site cause I dont get this "proof" calculations :shock:
is 40% = 80 proof ??
HookLine
Re: hmmm
Post by HookLine »
Husker wrote:I myself would rather just do a better job of distilling, and scrap the carbon filtering altogether.
H.
That is the real answer.
Be safe.
Be discreet.
And have fun.
Uncle Jesse
Site Admin
proof
In the States proof goes from 0-200. So 100 proof is 50% ABV.
It's different in other countries, which is why when I think about it I try to use ABV to avoid confusion.
Uncle Jesse
Site Admin
Just thinking it's possible that in the EU when they say "chemical resistant" they really mean it.
Husker
Re: ...
Post by Husker »
Uncle Jesse wrote:Just thinking it's possible that in the EU when they say "chemical resistant" they really mean it.
You could be right there. I think in AU this might also be the case. Again, what the contraption is designed to do is to have 40% ABV "cool" booze flow through it. Thus, it would be closer to a container to "store" finished booze in.
Plastics which could handle long term storage, would probably work just about the same for this filter. However, like i mentioned, I myself do not know what would be "safe" and what would not be safe as far as plastics go, so I simply do not use any of them anywhere. Possibly overcautious, but then I do not have to wonder just what I am drinking.
H.
HookLine
Re: ...
Post by HookLine »
Never seen beverage spirits sold in plastic in Australia. It is all glass as far as I know.
The Chemist's view on this is:
SOME plastics are okay to store LOW PROOF alcohol in (polycarbonates only, please--unless you really CAN afford PTFE)--NO PLASTIC is good for hot or high proof alcohol.
Don't do it. Don't argue. Or at least don't blame ME if there's ever a problem.
on page 6 of this thread
http://homedistiller.org/forum/viewtopic.php?t=3603
It seems so much easier to just avoid mixing plastics and alcohol above about 20% abv.
Be safe.
Be discreet.
And have fun.
new_moonshiner
Post by new_moonshiner »
why not just add the carbon to a glass carboy and let spirit set on it and then siphon off after settling for some time .... that way no plastic comes in contact with it ..
AfricaUnite
homedistiller.org mentions using plastics in the polishing neutral spirits section.
"Materials
1 x 500mm long 50mm diameter upvc pipe
1 x 50mm end cap
1 x 50mm threaded adapter
1 x 50mm threaded end cap with O ring
1 x poly pipe barbed adapter (see drawing/see text)
1 x Caulking gun glue tube nozzle
1 x Aquarium air tap
1 x 1 meter+ of silicon aquarium air hose
I used to use this setup and still have it in my shed, it produced the cleanest neutral spirit for me. Ive tried the carbon in gallon jugs and that cleans it up to a point (and certainly good enough for mixed drinks) but I havent been able to get it as clean as using a tower.
new_moonshiner
I agree with AfricaUnite, I guess the way i look at it is if sitting in a glass jug with carbon wont fix it then what do i have anyways , time to rerun in my book..
