running a still in the winter
countr3y boy
Post by countr3y boy »
Running a still when the temp outside is below freezing, is it possible and if so does it have any effect on quality of product?
T-Pee
Re: running a still in the winter
Post by T-Pee »
Quality depends on the fermentation.
Possible? Yes...to a point. You may get a tiny amount of ABV increase due to passive reflux depending on the height of your column but that is open to conjecture.
tp
countr3y boy
Its a pot still I had trouble getting paste to harden bc of the vapor was condensing and keeping it wet and also I could here condensed vapor dripping in the thumper
T-Pee
Post by T-Pee »
Paste it up earlier in the run during warmup before the rig really begins putting out vapor so it gets a chance to cook and harden.
tp
countr3y boy
Ok sounds good. Wat about the vapor that is condensing in the lyne arm and dripping in the thumper is it possible it could over fill the thumper?
Tokoroa_Shiner
Post by Tokoroa_Shiner »
If your thumper is the right size it shouldn't be a problem.
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
S-Cackalacky
Post by S-Cackalacky »
Maybe you could insulate the lyne arm and other parts if needed. Not so much to keep the heat in, but to keep the cold out.
cuddy-boozer
Post by cuddy-boozer »
S-Cackalacky wrote:Maybe you could insulate the lyne arm and other parts if needed. Not so much to keep the heat in, but to keep the cold out.
+1 on insulation. Some of that foil tape would work well
Danespirit
Post by Danespirit »
countr3y boy wrote:Ok sounds good. Wat about the vapor that is condensing in the lyne arm and dripping in the thumper is it possible it could over fill the thumper?
The dimensions of your thumper should at lest be 1/3 of you boiler, then you are golden...
