Reusing wood Chips
Reusing wood Chips
Hey all I was wondering if you can reuse wood chips after you have used them to flavour your alcohol?
- dstaines
Re: Reusing wood hips
You can do whatever you want. Used wood, especially wood chips I think because of the higher surface area to volume ratio, will have diminishing returns. Less color less flavor more slowly. But I've found that i like the of my spirit better when aging it on once used charred oak dominoes than with freshly charred dominoes
I buy all my liquor at the hardware store.
- S-Cackalacky
I reuse my JD chips in the charcoal grill. They make for a damned fine steak.
a lot of people I think use them a second time in some way or another. I just pull some bourbon off French oak spiral and put it in a single malt scotch . its got a nice nose to it at this time and color is starting to change color slowly.
Thanks guys I'm just trying to figure out what to do. Whether I buy a couple of oak barrels. Or I have a unlimited number of kegs. So I'm thinking of using the kegs for storage and just adding oak chips or dominoes. Another question is if I did go the way of the oak barrel how long do they last. I'm thinking about changing to a smash, over essences and wonder how many time you can continue to keep using a oak barrel
- dstaines
Re: Reusing wood Chips
I think we need to hit the brakes here. How much liquor are you trying to age and store in your unlimited number of kegs?
Not sure I'm thinking only prob 80-100 litres why?
