I've been using a modified All-Bran recipe using Cinnamon Toast Crunch for a few runs now - I had really good results the first time I did it and that's why I stuck with it a bit, but lately I've been struggling with it producing a very small bit of hearts before the tails kick in.
I ferment five gallons of the stuff (1lb cereal, 7.5lbs sugar, 5 tbsp bread/grocery store style yeast per five gallons), do stripping runs, do the five gallons again, and put the product of both stripping runs together for my spirit run.
I collect 1 cup at a time for my spirit run (I run a 4 gallon pot still, medium-to-fast for the stripping runs, and slow-to-medium on the spirit run).
But I swear, by jar six I'm already well into tails. That's a lot of work to end up with less than a third of a gallon of hooch.
Is this just a standard problem for such a smallish still? Or should I try another recipe? I've never been a fan of whiskey, but I've never made it. Maybe the unaged stuff I might like, I'm willing to give it a shot if I have a chance of getting more than one quart jar out of ten gallons of wash and like eight hours worth of runs.
Too much tails. Is it my recipe?
- bearriver
Re: Too much tails. Is it my recipe?
Yes on both accounts.
Small stills produce small yields. I don't have a 4 gallon still, but less than half of a gallon of hearts per 5 gallons of wash sounds right.
We will always recommend following a tried and true recipe exactly over experimental washes for obvious reasons.
My advice is to try Rads all bran exactly after you buy a keg boiler. Your yield woes will vanish into thin air.
Save those feints for all feints runs. They be tasty indeed. Also, most folks with a pot still prefer the flavor of doing stripping runs before spirit runs.
+1.bearriver wrote:....My advice is to try Rads all bran exactly....Also, most folks with a pot still prefer the flavor of doing stripping runs before spirit runs.
All bran makes a great neutral. And Rad's recipe is 100% "scalable"....you can tailor it to what ever wash size you need.
i'd guess best case scenario with 10 gallons of 10% (your recipe) going into a 4 gallon rig, you would do 3 runs of 3.3 gallons and have result of almost 3 gallons of low wines averaging 33%?
put that in for a spirit run and doubling it would leave 1.5 gallons averaging 66%
60% of the take being hearts thats .9 of a gallon if everything was perfect and you had no losses to solution.
but since it ain't perfect, if you got a half gallon of keepers you would be winning the race, and the extra gallon of feints is gonna add up quick and give you a lot more to work with over the course of a few months.
take BR's advise and get a bigger boiler. and a brute trashcan (or two) that will hold 20+ gallons of wash. then you can use the 4 gallon to finish some nice brandy runs or something.
now i drink for evil.
I've read that yeastdon't like cinnamon, so the cinnamon in the cereal that you are using could be effecting the yeast. Have you checked your starting and finishing gravity?
If you are not living on the "Edge", then you are taking up too much space!!!
