after reading a lot about reflux column
Posted: Tue Dec 25, 2007 12:18 am
mainly from this site/forum.
i read about inline,off head and vm(lately).
i recently was aiming for a inline then recently saw a a very elegant VM column.
Bokakob design are cost effective and proven true.
VM i dind't saw much about it "yet" except that just looking at one logic tell me they are very good, mostly cause of there simplicity.(down side is the gate valve that should be stainless steel not cost effective)
lucky me a had some lab glass doing nothing mixed with a cheap ss pot a hotplate and some imagination i get 92% at 250ml/h
that keeps me happy will i design/build a real column.
anyway all that to ask if that a VW column worth it over a simple bokakob.
and in the long run ill probably end up making a potstill and using the column only to recycle the tails and stuff.
some would say think about what you like then aim for that.
i like a lots of stuff gin,rum,scotch,vodka,some liqueur .... etc
so i probably need both a column and a potstill.
gonna aim for column first, not too good with fermentation yet, used to make kit wine that a monkey could do.and BW that also can be done by a monkey.(thank you birdwatcher that recipe is so easy)
if i do go for the Bokakob design the one with plates soldered in the column since i have no idea where to get a plate of copper, think i can use a piece of the 2" pipe cuted length wise and hammered down to a plate?
sorry if this post is a bit confusing been sampling the stuff...
thank you
pikluk
thank you
pikluk
