boiler
Heh. Monsanto does everything.
Who knows? It could be as harmless as a little bit of glyphosate (roundup; I've ingested enough of that stuff in my lifetime by spraying in a tractor without a cab), or it could be something a bit worse. Think a minute. If it couldn't be stored in cheap plastic barrels, and it had to be stored in SS, it might not be something that you'd like in your booze and it might be hard to wash out.
I really don't know what could be in there, but I'd want to play it safe.
"If you can't dazzle them with brilliance... baffle them with bullshit."
"Don't steal. The government hates competition."
"Believe none of what you hear, and only half of what you see"
20lt small pot still, working on keg
SS is resistant to most chemicals..
to be on the safe side boil a costic cleaner in the drum like drano then give it a good scrub.
wear rubber gloves dont get it on you, dont breath in the vapours.
rins well with water..
want to be on the safer side rinse it with vinegar
then rinse with water..
leave it sit full of water for a few days...
if the contents kills you after that it was your time to go...
