pint's condenser
Ricky
pint's condenser
Post by Ricky »
pint if you would,please tell us a little about your condenser for your big rig. how well does it perform compared to a worm or liebig? how much water flow does it need? can you put the inner part in a 15gal keg and not change water on a 10gal wash? how hard is it to clean? are you pleased with it? how difficult was it to build? the reason i ask all these questions is because i am trying to figure out a condenser that will match up to my copper pot i am going to build and i dont want to circulate the water if i dont have to. i tryed a worm and the worm won this time but i may make another attempt if your condenser doesnt fit my bill. thank you!
Day Late;Dollar Short
pintoshine
Re: pint's condenser
Post by pintoshine »
Ricky wrote:pint if you would,please tell us a little about your condenser for your big rig.
My condenser for my big rig is quite a nice condenser. It is a double walled cylinder with a input to the inside of the two walls at the top and an outlet at the bottom on the opposite side.
The dimensions are 400mm tall by 250 diameter with 6mm in between the walls.
This gives a cooling surface of 0.62 square meters.
This is the equivalent to 12mm tube 16.5M long.
I read your post about losing to the 3/4" copper.
it would be like having a liebig or worm in flowing water made from 1/2"(12mm) 54 feet(16.5M) long. It works great for a lot of throughput.
The water flow depends on the heat input. I run 100 gph through the shell. That keeps it plenty cool running 4 gallons an hour from the big pot. The spirits come out the same temp as the water.
can you put the inner part in a 15 gal keg and not change water on a 10gal wash?
I would think that would be ok but you would not have to build the condenser as big as the one I built. And you could use wineo's trick of starting with ice water made from frozen containers of ice.
as a comparison, one of this style that is 3 inches in diameter by 4.5 inches tall has the same surface area as a liebig 3/4" by 36"
which is larger than most people run on the 15.5 gallon keg.
It isn't. I just flush with clear water when I'm done.
It knocks vapor down extremely fast and It is the least maintenance part of the whole system. I like it a lot.
It was not too difficult but not trivial either. First I made the outside cylinder to the given diameter. I drilled and sawed the holes for the input and output respectively, and soldered in the tubes. The tubes were flared to make a snug fit once inserted from the inside. Then I made the inside cylinder to spec. I turned out the top and bottom edge, perpendicular to the cylinder wall, so that the diameter of the edge was the same as the inside of the outside cylinder. I slid the two together. This was a bit difficult because I had the tolerance a bit snug and had to pry the edges past the tubes. Once I got it slid in, I fluxed and soldered the edges to the outside cylinder. I then pressure tested it with 15 psi and soapy water.
The tricky part on mine was mounting it to the inside of the canister I made. The canister is sealed so I had a couple of tries getting everything leak proof.
punkin
Post by punkin »
Ya didn't happen to see the post below where i made a smaller cop from the design you gave me, Pint?
http://homedistiller.org/forum/viewtopic.php?t=5697
I'd appreciate a little input as to whether you think i'm on the right track, and if you could figure out the equivalent liebig size for me?
SorryToStealHisAttentionRickyPunkin
Ricky
Post by Ricky »
pint i thank you very much for the detailed reply. i know it was a lot of questions but i wanted to know the answers and i thought it would be a good resource for the forum also. i would have never guessed that it had the equal cooling power to such a large liebig. sounds great.
Ricky
Post by Ricky »
punkin dont worry about grabbing the attention. from what i can tell from your condenser they both look the same but different. i might be wrong though. we can get coors in a 5liter "mini keg" here and i am thinking about putting a 2.5in pipe in a 3in pipe to make my inside cylinder and putting it all in the 5ltr keg. i know i will still have to circulate water but if i figure right it should be equal to a 6ft liebig. and with the proper paint job would look like a mini wooden keg. should save a lot of space and look cute to. not to mention should be plenty of condenser for a 15gal keg or a 12gal copper still. i hope.
punkin
Post by punkin »
Sounds a very ggod idea, Ricky.
I reckon it'd work well.
The only difficult bit will be making the end caps, but if you use bought caps like i did it's not so hard.
Either use a holesaw the rigth size, or do what i did and use a die grinder.
Finnish with a file. :)
