Building a boiler out of a sand filter
A while back I bought a really big stainless steel sand filter at a junk store. From the measurements it would appear to be 15-16 gallons, kinda hard to say since the sides aren't straight and the ends are rounded. Didn't know what I was going to make out of it but figured it would be good for something. Anyway, decided it would make a good boiler, so I ordered the SS fittings for the project, so here it goes.
The filter was made in two pieces with a clamp, that way it could be taken apart to renew the sand. I didn't get the clamp that went with it. But that don't matter, since I'll be throwing way the rubber seal and welding the two half's together.
Figure on having a 2" gate valve for a drain, 3" ferrel on top for the vapor outlet, a 4" ferrel for the fill port and weld on two 1" NPS nuts for the heaters. I'll have to figure out a three legged stand for the boiler that's tall enough so I can drain it into a 5 gallon bucket, so I can use the boiler for heating water for mashing. Kinda figure to go slower than normal on this project since it's a case of wanting it but not needing it.
But it will still be crude by the standards of some of the builders here.
This topic has 125 more replies
Register Login
