We distilled 2 3 gallon corn washes today. The first wash was with a reflux. The second we did it more of pot still. The second run is slightly cloudy.
What causes that?
Will it clear up? It is 45%ABV. That is fairly strong. Alot of corn flavor in it.
CLOUDY CORN RUN
This is the first time we run this unit as a pot still. All we did was remove the middle 2 foot section of column from the reflux and thenremove the series of cooling lines thru the top part of the column.
I thought it was running to dang hot, but it would either stop dripping all together or the thermometer on the top of the column was at 85C.
I would turn the propane down to almost extinguished and if the temp started to drop, it would drop to 60C. We were using a 7 gallon keg and we only had about 3 gallons of wash in it. I will try and master the entire propane thing next time.
The bit of haze doesnt seem to affect the flavor in a negative way, it still has a nice corn flavor. In fact I drank probably about 5 ounces of it last night.
It is nice sipping whiskey. Just not pretty sipping whiskey.
You should just not worry about the temp when running in pot mode.Just set it so your getting a steady output,back down the heat as much as you can while keeping that output,and your set.Then once you see what temp it starts running at,you can use it for a guideline.I can run mine without a therometer but just use it as a loose guideline of my runs.Mine starts running good at 182-184f and I usually get into the tails at 200f or over,and quit at 203-204f.Yours will be different.You just have to get used to it,then you will know your temp guidelines.
When I first started distilling, I got this a lot. It was because I was greedy using my pot still. If you started at a normal 65 to 70% abv at the heads and ended up with a lot of 45% after collecting, this tells me you must have collectd a lot of tails and added to the batch. Most of the time tails from corn will cloud the spirit. I have had some be both cloudy and blue at the same time and make it look like blue milk.
So next time do a water louche test when you are getting close to 45% coming off the condenser. usually half spirit and half water will show it up as a cloudy whitish mixture. As soon as it appears start tossing it in the tails bucket. A small amount of cloudy tails can cloud the whole batch. Occsionally, I distill a batch on a coil that I rinsed with my tap water and it comes out cloudy from the beginning. I usually just throw the whole batch in a seconds run batch. I have learned to carefully not blow into a wet coil. This is almost a guaranteed blue spirit run. CO2 and water makes a blue salt that comes out in a run and makes it ugly. Distilling a fermenting batch can do this too.
