a question for my friend
Posted: Sun Jan 20, 2008 10:23 pm
by Usge
how thick the copper need to be for the bottom....if say you making copper still from sheet template?
_translation from Italian to sort of english_: if you are bulding a still from Pinto's template of 6 gal, how thick does the bottom of the still need to be for direct heat (ie.propane/gas)? It doesn't say.
This from my friend from Venice.
Posted: Mon Jan 21, 2008 1:19 am
by pintoshine
The one I just constructed and tested with direct heat is .032"(.812mm) or 20 gauge. As long as there is liquid in the bottom, it will never get hot enough to melt the solder.
Posted: Mon Jan 21, 2008 4:36 am
by goose eye
round here mostly it all made of 16 oz but some put 20 oz botoms. scorchin will have you makein new botoms.
so im tole
Posted: Mon Jan 21, 2008 6:53 am
by Usge
Thanks guys.
Goose..was that "gauge" (ie..16 or 20 gauge?)
Posted: Mon Jan 21, 2008 7:52 am
by Husker
No.
One other way to purchase "some" sheet metal, is in ounces per sq ft.
Here are the xref information for copper 110 sheeting:
0.00405" (3 OZ.)
0.00675" (5 OZ.)
0.0135" (28 GA.) (10 OZ.)
0.0162" (27 GA.) (12 OZ.)
0.0216" (24 GA.) (16 OZ.)
0.027" (22 GA.) (20 OZ.)
0.032" (21 GA.) (24 OZ.)
0.043" (19 GA.) (32 OZ.)
0.048" (18 GA.) (36 OZ.)
0.0647" (16 GA.) (48 OZ.)
0.086" (14 GA.) (64 OZ.)
0.097" (13 GA.) (72 OZ.)
So, pint is using 24 oz or 21 gauge sheeting.
H.
Posted: Mon Jan 21, 2008 9:28 am
by Usge
Thanks Husker :)
