1" Liebig Condenser Build
Posted: Mon Nov 09, 2015 12:16 pm
by pope
Firstly, while I read often it's been a while since I've opened my mouth on here, so I just wanted to say thanks for the unending wealth of information, this hobby has been immeasurably enhanced by the users of this forum. I know there's not really new ground to cover on building a simple liebig, but after putting together and running a 1 gallon claw hammer still over the last two weeks I was impressed by how well the tiny condenser did.
I'll cover that kit first: It's a 1/2" coming off a 1" column on a 1 gallon pot, the kit came with a 90 elbow to send the condensate pointing straight down, so I kicked it out with a 45 and added a generous stuffing of copper mesh to the inside, and the 5-6" length of 3/4" jacket does impressively well - my hot plate pushed it to the max and I pulled about 28 oz or so of 67% gin in about half an hour. Now I can make macerated/infused spirits one bottle at a time to my hearts content.
So, looking at my sankey setup, I'm currently using 2" pipe to a long and awkward 1/2" in 3/4" condenser (roughly 4-1/2' of jacket). I descends from the head at maybe 20-25 degrees and with 5500 watts and no insulation (lets not get into my laziness regarding insulating the kettle, I know I could at least use blankets). I can just barely keep my condensate down if I keep my water running high. Tinkerer that I am, I can't help thinking maybe I can make something a bit more compact and as (if not more) efficient.
If I go from my existing setup to a 1" inside a 1-1/4" at 45 degrees, I'll lose a little contact time due to the angle but otherwise I should theoretically be able to make it half the length of my existing setup and achieve the same internal surface area with twice the volume. I'll be able to fit even more copper mesh inside the greater volume, so I should be able to achieve even better surface area and slow down the vapor, which should also come out with less pressure.
The pros are: compactness (3' liebig will only reach 2' out and 2' down from the elbow, with the right column height a parrot will sit very nicely next to the keg) & rigidity. That and my old head will be proudly passed on to some friends keen on entering the hobby.
Since most people run 1/2 in 3/4, I thought I'd see if:
1. anyone has a condenser as (or nearly as) described
2. the 1/16" diameter ring of coolant (due to thickness of material) flowing between the 1" and 1-1/4" seems like enough volume
3. there are any general tips or suggestions based off this design
I could add a sketch and a parts list by request but for such a simple topic I know this is already awfully long. If/when I move forward with this I'll share some pictures.
