Cleaning your new still correctly
jb-texshine
There has been much confusion lately about how to properly clean a still before you take your first sip. This post is in hopes of lessening that confusion.
Remember: It doesn't matter if your still is made of copper or stainless or both or if it is soldered or welded these cleaning steps are the same and must be done! They are for your own personal safety!
Before beginning cleaning runs it is recommended to manually clean any solder joints or welds by hand with a rag or sponge to remove as much residue as possible. If you build your own still as you solder or weld reach in and wipe down solder or weld joints as you go to make cleaning runs easier.
A good idea is to start two ferments before you begin your still cleaning runs,one to be used for the sacrificial alcohol run and another for keeping to drink.Remember that the sacrificial run gets dumped out,NO EXCEPTIONS!
Soaking in a vinegar overnight coupled with a manual scrubbing in addition to the three cleaning runs is also a good way to help get rid of flux and other residues.
First: Water. Fill your still 3/4 full and attach colum,cap,riser, and your condenser,worm,Liebig,shotgun,or other. Do not supply cooling water yet. Bring water to a boil until you get steam blowing out of your condenser,let steam blow for 15-20 minutes at full heat, then turn on condenser cooling water or fill flake stand. Let run about an hour.
Second: Vinegar and water mixed half and half,fill boiler half way and follow directions for first step.
Third: Sacrificial alcohol. Sacrificial means it gets dumped out when your done. NO EXCEPTIONS!!! I recommend that you use a tomato paste sugar wash for this step as it is cheaper than box wine or cheap vodka. Add wash to boiler TURN CONDENSER WATER ON!!! Turn heat on, wait untill it starts to flow,don't get So excited that you taste this alcohol,collect all distillate down to about twenty proof, then DUMP THE ALCOHOL OUT!!! DON'T KEEP THE BACKSET EITHER!!! Dump or drain boiler,rinse boiler,inside cap,column,or riser and inside condenser with water only and allow to drain dry.Repeat as necessary. Remember,it ain't clean untill it is clean.
The reason for the three separate cleaning runs is some chemicals, compounds and substances are broke down in water some in vinegar and some in alcohol. ALL THREE ARE NECESSARY FOR YOUR OWN SAFETY!!!!!
Hope this helps,and remember, stay safe and happy stillin !
Jb
Jb
Deo Vendice
Deo Vendice
jb-texshine
Re: Cleaning your new still correctly
Typed this up for the new members,if anyone has anything to add let me know and ill put it in.
Jb
Jb
Deo Vendice
Deo Vendice
Very good JB.
Maybe we can get it to sticky, so it's always at the top of the list. Often new distillers overlook the most fundamental of instructions...and come asking. You've got it all outlined.
Thanks.
Thanks.
jb-texshine
Thank you sir.
Jb
Jb
Deo Vendice
Deo Vendice
- dl76
I cean my still with well water... after a run or two... that city water has all kinds of crap in it...
- dl76
My well is a natural spring...
StillLearning1
In the novice section somewhere there is thread about cleaning a new still. I think it is a stickey. It talks about doing a mild acid soak prior to a good manual cleaning before all the cleaning runs.
I soak new parts in a vinegar water solution over night and then scrub them the best I can prior to the clean runs. I think this makes a world of difference. Usually by the end of my sac alcohol run the distillate looks/smells fine to drink. I never do though.
I'd say add a good manual clean to this list JB. Good looking thread!!!
But what the heck do I know.....I am still learning.
- Truckinbutch
Good post . cut right to the chase . Even the rankest newbie should be able to grasp that .
jb-texshine
Thanks sl1
Tb I hope so. I think its kinda funny how they don't want to throw out the sac run....while holding the keys to the liquor store!
Deo Vendice
Deo Vendice
- S-Cackalacky
Good write up jb. I think, all too often, the manual cleaning isn't emphasized. It's a very important step and avoids having to do multiple sac runs to get all the flux out. It also helps to remove that gritty/oily manufacturing gunk that always seems to be present in new tubing.
For the manual cleaning, I use a wad of cotton tee-shirt with two pieces of kitchen twine tied to it. I put a small metal nut on the two ends so I can drop the twine through the tubing. I saturate the wad of cloth with warm soapy water and pull it back and forth through the tubing using the two strings. I do a second washing the same way, but with fores, or denatured alcohol. That, coupled with the other cleaning runs will leave you confident that you have a clean still for your first real run.
- HDNB
+1, i like a good overnight vinegar soak too. then a good ragging out. then the hot runs described.StillLearning1 wrote:In the novice section somewhere there is thread about cleaning a new still. I think it is a stickey. It talks about doing a mild acid soak prior to a good manual cleaning before all the cleaning runs.
now i drink for evil.
jb-texshine
Added overnight vinegar soak and scrub out.
Deo Vendice
Deo Vendice
jb-texshine
Any other suggestions
Deo Vendice
Deo Vendice
StillLearning1
I vote that this thread be directly linked in cranky spoon feed section. The spoon feed thread points new members to the correct place to find the original cleaning thread, but we all see how often it actually gets read. so if cranky feels inclined, id like to see it happen.jb-texshine wrote:Any other suggestions
On a side note. Coming to this hobby with no former brewing experience, I'd like to see a thread on how to properly clean fermentation vessels, hydrometers, ect... now I know sanitation in the distilling world can be debatable, but I've never seen a thread here outlining the proper way to do it.
Monkeyman88
Scrub with hot water if you feel like it.StillLearning1 wrote:On a side note. Coming to this hobby with no former brewing experience, I'd like to see a thread on how to properly clean fermentation vessels, hydrometers, ect... now I know sanitation in the distilling world can be debatable, but I've never seen a thread here outlining the proper way to do it.jb-texshine wrote:Any other suggestions
- pfshine
Am I the only one that doesn't like to bake the flux on with a water run prior to the vinegar run. I do a manual clean a soak then vinegar then a crapahol run. I rinse it out and its ready to go.
- Snackson
I've always followed this advice,
http://homedistiller.org/forum/viewtopic.php?t=15489
StillLearning1
I've heard at least one member saying that they like to let ferments sit for a month or longer before running. They think it improves taste .Monkeyman88 wrote:Scrub with hot water if you feel like it.StillLearning1 wrote:On a side note. Coming to this hobby with no former brewing experience, I'd like to see a thread on how to properly clean fermentation vessels, hydrometers, ect... now I know sanitation in the distilling world can be debatable, but I've never seen a thread here outlining the proper way to do it.jb-texshine wrote:Any other suggestions
So what your saying is I can scrub a bucket with hot water and then have no worries of infection two months later?
Like I said, I know its a opinionated subject but there may be people like myself that would like to know the proper way to sanitize equipment. It was just a suggestion.
Pf----- I've never done a plain water run. Just soak, scrub, 50/50, then sac. Works for me.
- pfshine
Thank you snackson for the reminder of the post that has been here for a while. Still learning. I use bleach if I leave it set for a while or get an infection. Then rinse the bejesus out of it.
Monkeyman88
Yea. Lots of different opinions. And depends on your location. I haven't cleaned a single thing since I started three years ago. Others clean after every ferment.
Jolly_Roger
I think that before you even start cleaning your new still it should be recommended that a novice get a wash started that will be drinkable. It's a lot easier to toss your first stripping run when they know there is something good waiting to be run.
There is a lot of effort and time that goes into getting to that first spirit run and you can only harp on "patience" so much
IMO
IMO
All grain goodness without the nasty fibre
- S-Cackalacky
For fermenters, I use StarSan. I keep a 5 gallon bucket mixed and ready to use. I have a small handheld garden sprayer that I refill from the bucket. The sprayer holds about a half gallon (or less) and has a pump to pressurize it. When I put my ferment buckets (or any other equipment) away, I give it a quick spray of StarSan and again just before I use it again. I use plain water to wash equipment after using it.
I just recently ground and pressed ground drop apples (4 bushels). As I did the grinding, I dumped about 2 dozen apples at a time into a 5 gallon bucket of StarSan solution before transferring them to the grinder. The ground apples were in the fermenter for 30 days with no sign of infection. StarSan is good stuff.
- S-Cackalacky
Good point. For a complete newbie, it's also good practice for developing fermentation skills. My first sac run was with a "Wineo's Plain Old Sugar Wash". I never could understand why others recommend using a cheap box wine for a sac run - it ain't necessarily cheap. And, there's no learning curve involved in dumping a box of wine into a still boiler. I also agree that it would be good to do parallel ferments - one for a sac and the other for the first real run.Jolly_Roger wrote:I think that before you even start cleaning your new still it should be recommended that a novice get a wash started that will be drinkable. It's a lot easier to toss your first stripping run when they know there is something good waiting to be run.
IMO
jb-texshine
Hows that guys.
Thanks for the suggestions. Anyone got any other suggestions?
when I did my sac run I used takka vodka but I had two half gallon jugs that were left over from parties,plus I bought one. Already had my first ujssm fermented when I did my sac run too..
I would be honored if this post ended up stickied,or linked in cranky's spoon feeding post but all y'all are helping with it in just typing it up. Wouldn't be near as big or thorough without yall.
Jb
Jb
Deo Vendice
Deo Vendice
Keico2015
I have to say that after constructing my pot still, and using silver solder, I had wondered how was I going to clean the inside, of the flux and small pieces of silver solder that had gotten on the inside.
This was just what I needed and I wanted to say thank you so much for taking the time to share this valuable information.
My only other question is I know it is said to get a scrub brush somehow in there to scrub, but what do you do when you are working with a 1 1/2" opening as the only means to getting inside the pot still.
A carboy brush will fit through the opening and has a long "wand" handle. Go to you local homebrew store and they'll be more than happy to sell you one.
- FreeMountainHermit
Just did a cleaning run on the 2 plater with 50/50 water/vinegar.
Ran 13 gallons down to the element. Steady constant steam for 3 1/2 hrs out of the PC.
Enough ????
Enough ????
Blah, blah, blah,........
Are you satisfied it's clean, then sure...enough.FreeMountainHermit wrote:...Steady constant steam for 3 1/2 hrs out of the PC....Enough ????
But Keico asked about using a brush, so I wanted to answer his question. Sometimes a good "mechanical" cleaning is good to do before your very 1st cleaning protocol, ie - steam, 50/50 vinegar & water, and finally sacrificial alcohol run.
FHM, I think a good steaming is a good start. But not pre-emptive of the vinegar and sac runs.
Sac runs will follow when weather breaks. Have a 20 gal. wash waiting so it will be multiple sac runs actually to be safe and observe.
Maritimer
If you have used a grease-based flux, it can be very hard to remove. The only solvent I've found that truly dissolves it, and wipes it off like water on the kitchen counter, is toluene. Acetone won't do anything to grease-based flux. We had a lively discussion about this years ago--I remember mash rookie was lamenting having used a grease-based flux and rad insisted on using muriatic acid on the stuff.
Toluene is incredibly smelly. It's what the old contact cement used to smell like before the water-based stuff arrived. Or fingernail polish. Use it outside or your shop or garage will stink for days.
Muriatic acid is hydrochloric acid. Just a whiff of it can burn your lungs.
You can buy toluene at any hardware store. At the local Home Hardware it's called toluol.
Use chemical-resistant gloves. Toluene dissolves latex.
Edit: rinse off any toluene and dissolved flux with a garden hose.
