Best All Grain Press is a "No-Press"!
ga flatwoods
Post by ga flatwoods »
As an experiment I tried a new method of grain pressing to remove the liquids from the grain after all the free run has been pulled off and it is to brag about! The secret is in the filter material I used. I took a bucket that once contained chlorine tablets and drilled many holes up the sides and in the bottom. Removed the original handle and fashioned another of rope with only a little slack over the top of the bucket when picked up. Now for the magic. To this bucket I draped a piece of four once, non-woven, needle punched geotextile fabric that did not mquit hand all the way to touch the bottom of the bucket. The extra material on the side overlapp was tucked between the rope handle and the bucket itself. This bucket I now hung in the top of one of my 50 gallon ptfe drums suspended with a cross bar under the rope and across the top of the barrel. To this I now added my grain from the bottom of the mash barrel. As it filled the geotextile it tightened the cloth against the rope and bucket and remained suspended in the tab bucket. All of the remaining water gravity fed through the cloth and bucket into the barrel. It take a moment for a load to drip dry (30 minutes) but when dry it was CLOUD FREE!!!!! Easies method ever! This material is used a lot by construction companies to wrap the joints of concrete pipe to help ensure the soil does not leak into the joint when the pipe is running hard. In this manner it is a cheap insurance to the contractor installing the line. Otherwise, I do not know where it could be obtained outside of an unreasonable amount of material at a high cost.Maybe a septic supplier would carry it as well.
Good hunting!
Ga Flatwoods
I am still kicking.
Ga Flatwoods
This topic has 181 more replies
Register Login
