Thumper build
Re: Thumper build
What are the dimensions on it?
Re: Thumper build
1 ft. tall and 7 1/2 in. diameter.
Re: Thumper build
So almost 2.3 gal capacity. How big is your boiler? Don't forget to put a drain with a ball valve and large fill port. Tri clamps are great for all connections.
Re: Thumper build
Hopefully it's only a 5 gal boiler.
Re: Thumper build
7 is in spec, or at most 8 would be okish
Re: Thumper build
No ive got a good sized boiler, 17 gal., and I know the thumper is small but I think it'll do for now.
Re: Thumper build
That thump is way to small for that boiler. 1/3- 1/2 of boiler capacity is recommended for a reason. The thump can over fill and puke everything into your jars. Just not advised all around.
Re: Thumper build
Finish it and sell it. Make an inline thumper out of it. Lots of things you could do. Maybe keep it up high and have a return line to the boiler.
Re: Thumper build
I was thinking maybe a doubler?
Re: Thumper build
Huh? A thumper is a doubler.
Re: Thumper build
Slobber box sorry not doubler. My bad
Re: Thumper build
Sure. Why not.
