Hot plate usage
If it plugs in, post it here.
Smokee
Hot plate usage
Post by Smokee »
I finished up the triac temp controller and have it running a new 1500 watt hot plate. I've cranked it up and it gets hot and works well. Tonight I put the pot I'm going to distill with on the hot plate with 4 gallons of water and was going to do a test run and take it up to 180ish degrees. After a few minutes on max the hot plate temp controller, which I had set to max, tripped and shut down the current to the coil. Initially I bypassed the temp controller then reconnected it thinking it would work as an over temp switch, should I of kept it bypassed? Or, should I not drive the coil at max?
Hopefully hot plate users with experience could chime in on how they operate theirs. I'd really appreciate hearing how you run.
This topic has 16 more replies
Register Login
