Being new to any type of distilling,i'm trying to make a 20 gallon stainless pot still with an 8 inch stainless thumper. I have 2 in copper( out of a 6 in. cap ) coming from my boiler,then too an 8 in X 24 in. stainless thumper. From there I have 2 in. copper running to my worm. so my question is ,what diameter and length worm should i use and how quick should i reduce it down too the worm.
Also, is copper mesh needed for the sulphides seeing how I have almost 10 ft. of 2 in. copper lines. If so where should i place it ? In the top of the boiler near the outlet, in the thumper or can it be put in the boiler.
copper worm size
Re: copper worm size
Welcome to HD, to answer your question no copper mesh isn't required as long as you have copper somewhere in the vapor path. To answer your other questions I am a visual person and would like to see some pictures, I use a shotgun condenser and before that a libieg so not an expert on worm condensers.
- MoonBreath
Welcome to HD?
Hopefully you're utilizing the Parent site along with these forums.
Beins its 20 gal, you'd be ok with a 1/2"id or even a 3/4"id worm ...I'd say et least 25-30' of coil ..
The reducer can be rite after thumper, or rite before the worm.
If you're reducing at the lyne arm, lyne arm should be around 15-20" in length before reduction,
although I've seen some reduced rite from cap or elbow ...Personal preference I spect.
Hope I helped ...Get some pics in when possible.
No scrubbies needed, you've enough copper.
My first build. Looking for any and all imput. I only want to do this once .THE INFORMATION ON THIS SITE IS UNBELIEVABLE & YOU GUYS ARE GREAT. Bad thing is ive read so much my head is spinning and i'm second guessing everything .I am taking alot of notes but i just want to make sure with all the questions. Thanks everyone.
- Attachments
You sure that thumper is 10gals? Sure looks small. A thermometer in a pot still is not needed, but nice to have if you know how to use it. There's a thread in novices that is discussing that right now. Good luck, welcome and enjoy the forums!
5 gallon(ish)
This is not the 12 in. thumper. this one is just for reference. any advice on copper size or lengths.
Is there a link for this pic? I can't read it. lol I need new glasses. lol
or can someone summarize what it said?
It looks like it converts the sizes in to a proper set up?
If not is there a calculator to size out all the proper sizes of all the components?
