Best method for seperating corn from mash
Shovelhead89
Post by Shovelhead89 »
What is the best method for seperating out corn bits from a mash (sparging, false bottom, pressing, grain bag, ect.)
I will be direct steam injecting and using enzymes with an all corn grain bill in a 55 gallon stainless drum if that matters.
Re: Best method for seperating corn from mash
I know it is much easier (lazy) to re-ask a question than to search, but you only needed to look about 5 threads down for a discussion of similar inquiry. If you'd look, you can learn much.
But since I'm here...here's a hotlink: http://homedistiller.org/forum/viewtopi ... 9#p7413933
You should learn how to use the HDGoogle search....there is so much info there that you (obviously) need.
Shovelhead89
I've spent hours searching, trust me. It usually comes down to people just saying "yea it's going to be tough either way"
Do you believe pressing/straining to be the best method for corn then? I could hang a perforated bucket or bag from the trusses of my shinehouse and let gravity strain it back into my fermentation barrel. Are false bottoms no good for corn?
How do commercial distilleries do it?
bentstick
Post by bentstick »
Rack off what ya can and scoop out about 1/2 the grain with a colander and with what is left in the fermenter do a piggy back,and use up the grain and pitch the grain bed,if feel inclined,do another sugar head for a neutral/vodka type drink, three runs through and ya pretty much used up the grains and what is left you have no big loss of the usefulness of the grain.
This my practice anymore got tired of squeezing,and dealing with that mess,this my attempt to give you a constructive answer and my way of doing AG mash with out letting good grain go to waste :thumbup:
It is what you make it
MichiganCornhusker
Post by MichiganCornhusker »
Shovelhead89 wrote:It usually comes down to people just saying "yea it's going to be tough either way"
Yep. And that's all yer gonna get.
There's a wise man on here that suggests that you should never underestimate corn's ability to plug a hole.
Cracked corn strains easier, malted corn easier still.
But if you grind it up for better conversion, I've yet to see an easy way to filter it.
GAFlatwoods posted about a GeoTextile fabric that works good, and comes in larger sizes than paint strainer bags.
I broke down and built a steam stripper rig, and I'm not looking back.
I rack off the clear and use it to steam strip the dregs. Works a charm.
jedneck
Post by jedneck »
The coarser the grind the easier it is to drain. But the coarser it is the more efficiency goes down. Steam stripping is were its at. Rack the clear to the primary and dump the rest in the secondary. On a dual 15.5 keg setup should be able to run a total of 17-20 gallons.
big help
Dunder
A mop wringer and a big mesh bag
Squeeze about a gallon at a time.
Buy 2 or 3 bags. The first one your going to bust open by squeezing too hard :oops:
Here's a thought... If you aren't planning on reusing the corn why not mix something coarser into the mix in an effort to reduce the compacting and clogging that corn alone causes...??? There should be some relatively inert material that would work... Divide and conquer... Might be worth a try... Just thinking outside the box...
bitter
Post by bitter »
Rice Hulls might help.. does for beer making!
B
Pesty
Post by Pesty »
bitter wrote:Rice Hulls might help.. does for beer making!
B
they sure do!
I use them for sparging my AG mashes with a false bottom.
I go 2 lbs of hulls per 10 lbs of grain added at the end of the mash-in. Top off my tun with water, give it a good stir then sparge and set the bed.
rubber duck
Post by rubber duck »
shadylane wrote:A mop wringer and a big mesh bag
Wow that's a really good idea.
I'm not being sarcastic, if you've ever mopped a floor you will understand.
Shovelhead89
Do you get any off flavors distilling on the grain? I have an extra stainless drum kicking around and I'm almost done my direct steam injection rig for mashing, how much more would be involved in a making a steam stripping still?
MichiganCornhusker
I did remember a possible great idea for separating grains from mash.
The best quickest way that I had was to dump a bout a gallon of mash in a wire mesh kitchen strainer.
If you just dump them in, the strainer would plug up, but then if you did a quick jiggle with it, it would continue to drain. Sort of a horizontal circular motion, about 4 rpm.
This works really well for separating spent grains, but won't get it totally clear. And it's very tiring on the hands and wrists after about 30#.
I had imagined maybe cutting the bottom out of a bucket, lining the bottom with wire mesh, and then hooking it up to some kind of eccentric jiggler that could be run with a drill motor.
Remember those old "exercise" belt machines that you would stand on and put the belt around your ass and it would jiggle you? Something like that, but you know, for mash.
BoomTown
Post by BoomTown »
So this was a major problem for us. I think we've made great progress though...our goal being to not spend a fortune, but recover as much clean beer from our all grain mash to run in our still.
We went to an Army/Navy surplus store and bought a bunch of Mosquito nets for bunks. The nets are the kind we used in VietNam that mounted on small posts and draped down around our cots...
I Boiled and rinsed them about 4 times to remove the pesticides that the netting is soaked in. The netting is very strong, and solution neutral.
Then I made a cardboard cutting pattern that allowed me to make bags to fit in our fermentors. I can get 4 bags from each mosquito net, if I cut carefully and sew the pieces back together right. I cut and sewed these bags with double folded seams using nylon thread. Our fermenters are 30 gallon barrels, and the bags fit all the way to the bottom and loop over the tops about 6". Our fermenting barrels have separate metal clamps which we use to hold the bags in place as we fill them.
To use them, we put a bag in a fermenter barrel (30 gallon), and dump in the hot output from a Mash Tun, then place a top on the fermentor, allow temps to drop, toss in the yeast and ferment for a week to 8 days.
When the fermenting is done, we move the fermentor to the Pig. We tie the top of the bag with a loop of nylon cord, and hook it to a small block and tackle mounted on the ceiling joists to lift the bag filled with grain till the beer drips freely down into the barrel. Usually have to let it hang overnight, I like to squirt a little hot water into the top of the bag to restart the dripping, sort of a last ditch large to get the last of the sugars. Sometimes we simply swing it over to the pig and let it drip dry there, under pressure.
At this stage, we end up with about a 15% loss of the volume, but the beer works well in our electrically fired Still, as if it were cleared and syphoned off the top of the grain.
We've gone a step further to recapture the beer trapped in the grain by making what we call our "Pig". Our Pig is two 50 gal barrels, one having the its top cut off and a drain installed at the bottom. Inside, at the bottom of this barrel, we place its cut off top as a sort of false bottom inside this drum. This false bottom has ⅜" holes drill about every 2" to let the beer drip down, and a spacer keeps the grain bag up off the bottom about 3". The drain below the false bottom lets the fluids to drain away to a collector. The false bottom keeps the grain bag from plugging it up.
The 2nd barrel is cut length wise, and the sides drilled with ⅜" holes about 2" apart up down and all around. This is placed inside the first barrel - resting on the false bottom, forming a tube and we've spaced it away from the sides of the outside barrel. We've cut the top and bottom of the interior barrel to fit tightly the inside of our tube like a solid wafer. We drop a drip drained bag of grain into the tube. The solid wafer over the top of the drip drained bag works as pressure disperser, where we set a 30gal barrel, filled half way with stone and water, on top of the wafer, to squeeze the grain in the bags. We usually place two grain bags in the pig, separated by a solid wafer so the beer drains off the sides away. (I'm thinking we might work out a better 'press' for this step, but my thoughts are not fully developed yet...)
We recover another 5 gallons of beer per cycle this way. All and all, for a 25 gallon Mash, we usually end up with about 22 gallons of beer, then we sell the distillers grains to a farmer for animal feed, which helps.
If anyone is interested, I could post pictures next week.
Boom
Mikey-moo
Post by Mikey-moo »
Could you build a large 6 spoked merry-go-round style centrifuge - each spoke able to suspend a 5 gallon fermenting bucket?
It would need to be sturdy, but provided it was balanced properly it could be spun to compact the trub and allow a larger proportion of the mash to be drawn off.
Or would that be prohibitively expensive compared to other methods?
BoomTown
Post by BoomTown »
Mikey-moo wrote:Could you build a large 6 spoked merry-go-round style centrifuge - each spoke able to suspend a 5 gallon fermenting bucket?
gave that some thought, but the balance thing seems to be a big issue...centrifugal force is a major problem ...
bitter
Post by bitter »
Another option is a nice steam stripping setup. Make a striping run on the grain... and the run the low winds in your flute. That is the easiest.... also the most costly.
If you r doing UJSSM then not a big deal... to leave some.... If its an all grain you could do a gumball on the leftover... that would mean minimal loss.. and give you a sugarhead to increase output of your grain.
B
ga flatwoods
Post by ga flatwoods »
This ia a one hundred pound shrimper's basket. It is rigid and tough slotted all around and in the bottom. The four ounce nonwoven needlepunched geotextile cloth I used draped in this would work excellently to drain the mash with a clear finish. The handles are strong enough to support the weight to allow it to drain. As I have said before, this is "The best all grain straining method I have found to date!"
Ga Flatwoods
I am still kicking.
Ga Flatwoods
WIski
Post by WIski »
Siphon off the clear beer and use a paint strainer bag and a mop squeezer to get the rest. I can do 50 pounds of grain in 20 minutes. Let the separated liquid settle for a day or two and siphon off the clear again. This is a simple economical method that eliminates ball busting and hurling juice everywhere. :eugeek:
Shovelhead89
bitter wrote:Another option is a nice steam stripping setup. Make a striping run on the grain... and the run the low winds in your flute. That is the easiest.... also the most costly.
B
I'm leaning towards a steam stripping still. Can you point me in the right direction on building one? Can't seem to find any good build threads. I already have 90% of what I'd need to build one I think.
Shovelhead...just search for steam stripper. Its easy to find if you LOOK. You NEED to learn how to use the HD Google search function. You will not be spoon fed anymore.
And here's a BIG hint: there is a steam mashing & distilling forum.
MichiganCornhusker
Here is a link to my setup.
http://homedistiller.org/forum/viewtopi ... 92&t=60248
It's really just a big glorified thumper. Jed, Shadylane, and Brutal, have all posted lots about using steam.
Take a look at Shadylane's Bain Maire rig, too.
Shovelhead89
still_stirrin wrote:Shovelhead...just search for steam stripper. Its easy to find if you LOOK. You NEED to learn how to use the HD Google search function. You will not be spoon fed anymore.
Yea I've went all through that forum, thanks.
You know the whole point of a forum to ask questions and get answers and especially on this topic there are very few answers out there and the topic titles don't always lend themselves to being easily found. If you don't want to and can't provide useful information feel free to omit yourself from my threads.
Shovelhead89
MichiganCornhusker wrote:Here is a link to my setup.
Thank you for the link, very much appreciated.
Johnnywhiskey
Post by Johnnywhiskey »
Just to throw in my 2c, but if you are going to separate the liquid from the grain before fermentation, lauder it like a beer with a false bottom. Unmalted corn and rye is definitely stickier than malted barley, but I can do 10 gallon batches without too much difficulty--just sparge with as hot water as possible. And I have a pretty high grain bill per gallon. I usually do 27-30 lbs per 10 gal with 1 lbs of rice hulls. This weekend I did a 10 gal / 28 lbs batch and sparged with about 8 gallons of water and ended up with about 14 gallons of wash at 1.051. If things get really stopped up I drain off as much liquid as I can while mixing up the grain bed. When nothing is left add boiling water, mix up and drain everything again. It's not how you would want to make your beer, but gave me a decent recovery for a wash.
I tried separating after fermentation a few times and it was a pain. And in the end I think the recovery was less than the lauder method because you don't wash the grain and a lot of liquid is still trapped in the grains.
Certainly the best recovery would be to ferment and distill on the grain, and if I had the time and space I would build a still that could handle grain--bain marie or steam distilling. Of course with either you need to be very cognizant of the mash's ability to puke and plug up the still head--or plug the steam wand in the mash.
I would be very interested in any first hand experience with the flavor difference between distilling on and off the grain.
bitter
Post by bitter »
I have tasted both on and off grain distillations but not hte same recipe so hard to compare.
From what I seen distilling on the grain does give more flavor across but it can increase the tannins.
This site has a pic of a local setup to me that distills on the grain.
http://www.northof7distillery.ca/#!ourdistillery/c18bc" onclick="window.open(this.href);return false;" rel="nofollow
There product is very good also.
B
rgreen2002
Post by rgreen2002 »
Ga Flatwoods
Ga... I believe you are talking about the PET Needle-Punch Nonwoven? http://www.ktnonwoven.com/pet-needle-pu ... woven.html" onclick="window.open(this.href);return false;" rel="nofollow from the Best press...no press thread.
Oddly enough when I put the PET Needle-Punch Nonwoven into the google search I get a lot of hits for pond underliner. This can't possibly be the same stuff could it? It does look a lot like the ebay post stuff you mentioned in that thread... :think:
Hope I didn't hijack! :mrgreen:
HD Glossary - Open this
raketemensch
Post by raketemensch »
It probably is the same stuff. I believe what ga flatwoods found was pavement underlayment. I used it earlier this evening, to strain out a gumballhead, and it's great.
BoomTown
Post by BoomTown »
raketemensch wrote:It probably is the same stuff. I believe what ga flatwoods found was pavement underlayment. I used it earlier this evening, to strain out a gumballhead, and it's great.
So how can we buy small amounts, like 10 to 20 yards of the stuff? And what does it cost?
Boom
rgreen2002
What do we think about this...?
Storm Drain Sentinel
Found here: https://www.amazon.com/gp/product/B0025 ... BXPQYG1CTZ" onclick="window.open(this.href);return false;" rel="nofollow
In the last line of the product description: "Made of 8 ounces polypropylene, non-woven geotextile fabric. It's disposal dependent on the nature of pollutants being collected. Should be in accordance with local, state and federal regulations."
The polypropylene (not polyester which is what the stuff ga flatwoods originally posted on) should easily withstand low ABV mash/wash at ambient temps.
