hello from UK
hello from UK
Hi all. New to the forum and to distilling really. I am from the UK and have a pot still and half way through a boka build. I have run about 300l of mash through my pot so far so very mush still learning something new every time. I came to this site to get some help speeding up my pot and some help on the coil/cold finger on the boka so please look out for those posts and help out. Hope I fit here and my names mark by the way.
Re: hello from UK
Welcome to HD, lots of great information for your question in the build column build thread. Good Luck and be safe!
- Swedish Pride
Re: hello from UK
Hey Stinky, welcome in.
how quick are you running now?
Running too quick can be a bad thing too.
Don't be a dick
Re: hello from UK
Welcome Thatstink! Great to have you here.
I look forward to reading about your exploits in the near future![Smile :-)](./images/smilies/icon_smile.gif)
Re: hello from UK
Hi . 5-6 hrs from start to finish on 12.5l. I make a 25l mash and because of some confusion between USA gallon and UK gallon ended up with a pot that holds 20l to brim so at best I can run 17l. Either way its not the pot size that's the problem. I would like to find a way if possible to run 12l in half that time. Be it a bigger pot/burner/pot rebuild.Swedish Pride wrote:Hey Stinky, welcome in.
At the moment the pots a simple USA 5g stock pot with 15mm tube out the top to a coil (traditional worm)
The boka is a 2" 4ft column. That's as tall as I can go cos ceiling height. Although I might add to it at a later date.
Thanks for your warm welcomes guys.
Re: hello from UK
Welcome Thatstink!
I run a pot still with a USA 14 gallon pot, aprox 52 liters and that goes to a 36" liebig condenser and I run it on a outdoor propane burner.
I also do 25 liter ferments and when I am stripping them I can strip mine in about 1 to 1.5 hours.
When I do a 25 liter spirit run I am usually in the 6.5-7.5 hour range from first drips to shutting her down. Spirit comes out as a fast drip/barely broken stream to a pencil lead sized stream.
Now I have never used a worm condenser so I can't comment on how they should work but I am thrilled with my liebig.
What are you using as a heat source? Electric? Propane?
Cheers Wiz
Cheers Wiz
All new distillers please read Crankys Spoon Feeding
Re: hello from UK
currently using a cooker top. That's why I have the ceiling issue. funds mean one thing at a time. will move on to propane soon after the new stills up an running. To be honest a few months back I worried I was wasting money. now I am hooked 25l is taking me 12+ hrs. I could handle 6Wiz of Oz wrote:Welcome Thatstink!
Cheers Wiz
![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Re: hello from UK
I use a liebig condeser, never had a worm. My outlet on the liebig is 1/2" which is around 13mm
I have a 2 foot column coming off the top of my pot (for ease of collection) and then it goes to my condenser from there.
Heres a picture to make it easier
