Where can I buy SIDE AIRLOCK - Angular Airlock
Radek
Post by Radek »
Where can I buy SIDE AIRLOCK - Angular Airlock. I would like to assembly airlock on side of my fermentator, this will allow me to stock one fermentator onto another - my kitchen is not big enough to keep 6 fermentation buckets on floor :))))))))
Re: Where can I buy SIDE AIRLOCK - Angular Airlock
Blow one out of glass.
or
Get a six times larger fermenter. The footprint wouldn't be much bigger than a couple of your buckets.
Radek
Post by Radek »
in each bucket is something different :)
mash, fruit mash, barley mash .....
Radek
Post by Radek »
shell I mix them ? :) any idea where I can get that kind of airlocks ?
Radek wrote:shell I mix them ? :) any idea where I can get that kind of airlocks ?
I done told you already. Get some glass tube and blow one. What you are wanting is easy.
If you really cant do it, look for a local laboratory glass blower in your area.
Distilling doesn't need airlocks anyway. My current ferment has a towel over it.
cuginosgrizzo
Post by cuginosgrizzo »
as stated, an airlock is not needed. But if you can't do without it, just get a food safe tube, stick one end in the hole of your fermenter and sink the other end into a bucket of water with some starsan or chlorine.
keep a safe distance between the surface of your wash and the hole you make in the side of the fermentor, or you'll have to mop wash from all over your floor.
http://www.ebay.com/itm/SIDE-AIRLOCK-Ga ... 2184124180" onclick="window.open(this.href);return false;" rel="nofollow
Radek
Post by Radek »
You are star mate - Thank You
That money buys a lot of clear plastic tube.
Radek
Post by Radek »
Yep. But they looks much better that pvc tube and jar with water :) Thank You anyway for advise.
Swedish Pride
Post by Swedish Pride »
buy normal airlocks and get some small od copper tube that fits the bottom of the airlock, bend the tube and stick in to the side of the fermenter and stick the airlock in the copper tube, should get a fair few done for the price of one side airlock
Don't be a dick
Pikey
Post by Pikey »
I've got some airlocks somewhere :oops:
My current ferment is going on in 25 Litre fermenter, with the cap tightened down and then just baccked off a quarter of and inch or so - so you can just feel a little up and down movement in the cap if you pull it. Often I use a bit of plastic bag, with an elastic band (not too tight ) - so the CO2 can push it's way out fairly easily.
My big fermenter (200 Litre) would need some airlock when it's on song !
Not that there's anything wrong with airlocks at all - they're there to keep the vinegar bug etc out of your wort and in winemaking they can be very useful in the last days of fermentation and clearing - until the water in them dries out of course :shock:
Single Malt Yinzer
Post by Single Malt Yinzer »
https://www.amazon.co.uk/SIDE-GLASS-AIR ... B0189B6X02" onclick="window.open(this.href);return false;" rel="nofollow
http://domacialkohol.cz/kvasna-zatka-bocni-sklo.html" onclick="window.open(this.href);return false;" rel="nofollow
cob
Post by cob »
Radek wrote:Yep. But they looks much better that pvc tube and jar with water :) Thank You anyway for advise.
Who are you showing off your hobby to that your air lock has to be perfect instead of functional ???
Blarney Stoned
Post by Blarney Stoned »
Who ya showing your stuff to ? It's illegal.
Been making shine for over 25 years and never used an airlock. There are other ways.
NZChris wrote:Blow one out of glass.
My thoughts exactly :lol:
Building a Glass Angular Airlock is bigger bragging rights, than speeding money :shock:
Kareltje
Post by Kareltje »
When I made wine, I made my own airlocks out of two small medicinejars, two pieces of small plastic tube and some glue.
Glue the lid of the first one airtight and put enough water in the second one. When there is pressure from fermenting, the water will be in the second jarlet, when the fermentation stops and starts to suck, the water will go in the first jarlet but will not get into the mash.
Costs almost no money and can be used anywhere.
greggn
Post by greggn »
http://www.ebay.com/itm/SIDE-AIRLOCK-Ga" onclick="window.open(this.href);return false;" rel="nofollow ... 2184124180
A glass airlock ?!? I give that worse odds at survival than your average HBS hydrometer test jar.
________________
