what im looking for
dirtyshank
what im looking for
Post by dirtyshank »
hanks everyone
i already know what type o style o still i want,, i want an 8 gallon milk can, 2 piece dual purpose re flux/pot still column at 2 inch diameter..the longer the column the better... i would like to run it with a 1500 watt element with an amp/temp controller.. the temp gauges dont matter because i can always buy them as long as the holes are where they need to be because my soldering skills are none existent and i would rather buy than build at least at this point in my skills..
i'm a little scared to order from american companies like mile Hi distilling and brewhaus because im not sure how Canadian customs are?
i anyone in Canada has any advice please feel free to message me.
Still Life
Re: what im looking for
Post by Still Life »
You described one of Brewhaus' stills perfectly. Give them a call.
They are very helpful and I'm sure they have an answer.
KeenPin
Post by KeenPin »
I had a "kettle" shipped to Canada.
Transplanted southern redneck in the north.
Now I just need to get back to "My Island!"
dirtyshank
who did you order it from if you dont mind?
KeenPin
Post by KeenPin »
Brewhaus is who I got my kettle from and heating element. But I built my own column. You can always place 2 orders so that you are receiving 2 packages at different times to not raise any potential flags. Most home brew shops in my area are selling distilling equipment.
Check with http://brokenoardistillingequipment.com" onclick="window.open(this.href);return false;" rel="nofollow as well, located in canada.
I haven't ordered anything from them, but its an option.
The goberment has other things to worry about then you making a little drinking supplies. Just be discrete and take everything apart when not in use. I built a wooden box to store my condenser in and another box for my column.
bilgriss
Post by bilgriss »
The 8 gallon milk can boilers are nice. I use one with a controller and 1650 watt 110V element. Works well for me. About an hour and ten to reach boil on a 6 gallon charge, a little faster on a spirit run. Easy to use, easy to clean, nice and sturdy.
One thing to add. Many vendors sell the all in one package pot still including a stainless liebig condensor. I don't recommend that option. The stainless condensor is only about 18" in length on most of them, and in order to fully knock down your vapor on a stripping run, you have to use overly cold water, and can't really run wide open. Take the extra time to build or buy a longer copper condensor. I recently finished a 32" 3/4" over 1/2" and a triclamp adapter from 2", and it lets me strip at full speed, producing cool product, with minimal water flow.
Best of luck with your border crossing.
kimbodious
Post by kimbodious »
Welcome :wave:
If you go for a modular design you can buy the pieces separately. Some pieces, spools and tees, I bought from chinese vendors on ebay, some pieces including condenser and sight glass kit I bought from SD. Chech out the pics from my .signature for my 2" modular still system
Modular 2" Pot Still
CatCrap
Post by CatCrap »
I agree with what Bilgriss said. The condenser that comes with the brewhaus set up isn't enough. I have a 2" brewhaus ee psii, and i like everything about it except the condenser. I would have been better off getting the kettle and column seperately. But, if your going 8 gallon kettle, i'd assume you will be using 120V, one element or two if you have enough condenser. I bought this controller and it works out well. If you look at similar items on amazon, the same controller will pop up pretty often for even cheaper. I think i paid 6$ for mine. Pretty much just plug it in and your set, very easy for those like me that are not electrically inclined.
https://www.amazon.com/TruePower-123-Va ... 9DWNQMBHQ9" onclick="window.open(this.href);return false;" rel="nofollow
