I've got a batch of UJSSM underway, and I intend to use a 5500w ULWD ripple element w/controller to run it as a pot still.
In searches on this forum and others, I've seen different people both claim that:
1. An ULWD could never scorch even if you tried
2. That the wash needs to be completely cleared and run on half power to prevent scorching (no mention of element type)
I know that you can't run on the grain as a given, but I get the feeling that the truth of the matter lies somewhere in between. As long as fermentation has stopped and sugars are used up, and I rack liquid in without solids, would I be good to crank up the element to max for a stripping run if my condenser can knock it all down? or should it be turned down to avoid scorching on any charge that isn't as clear as low wines?
Wash clarity vs Scorching on Elec. Element?
- BDF
- HDNB
Re: Wash clarity vs Scorching on Elec. Element?
the only thing ive scorched was hi-rye. run lots full out until hot and dial back to run. my pc runs out at 17 a but i usually strip at 12 and spirit at 6.6-8.5
now i drink for evil.
- BDF
If you can run it on full for the heat-up, why dial it back when stripping? Trying to prevent puking? Condenser can't handle full power? other?HDNB wrote:the only thing ive scorched was hi-rye. run lots full out until hot and dial back to run. my pc runs out at 17 a but i usually strip at 12 and spirit at 6.6-8.5
- BDF
May have been over-thinking this.
Done two runs of UJSSM so far, mostly clear when siphoning, semi-opaque doen near the grain bed, had a cheese cloth sock over the inlet to the auto-siphon that kept large solids out. No scorching of any kind that I could tell.
- Swedish Pride
you can run it full tits if you want, I've done it plenty times with cloudy beer with grain bits in there.
never scorched, you can get a bit of grain bits on it though but that washes of easily
Don't be a dick
- dieselduo
I rack it through a mesh strainer and have never had a scorch with electric
- Kareltje
I believe scorching occurs when the solid parts can not move away freely and must stay on the hot spots.
I always use boiling cents on my gas stove and as long as they rattle the risk of scorching is low. But when they get stuck in the solids and stop rattling, the scorching starts.
So take enough fluids or use a stirringsystem or a thumper.
- Fart Vader
Been there done that.
Just try putting some trub or Lees whatever you want to call it with your ULWD element and see what happens.
I tried it.
Once!
Doesn't take much either.
I tried it.
Once!
My double walled boiler build: The Mashimizer. viewtopic.php?f=50&t=64980
- HDNB
my PC runs out of cooling at 17A. it's a 4x 1/2" in 2" shotgun, figger it's more of a vapour speed problem than a heat transfer.BDF wrote:If you can run it on full for the heat-up, why dial it back when stripping? Trying to prevent puking? Condenser can't handle full power? other?HDNB wrote:the only thing ive scorched was hi-rye. run lots full out until hot and dial back to run. my pc runs out at 17 a but i usually strip at 12 and spirit at 6.6-8.5
Stripping at 12A i don't risk overpowering the PC and the take off rate is not much slower than at 17 when it's on the edge of steaming and the recirc water gets hotter faster.
i turn up the heat when there is snow available.
