DavidR wrote:Pikey, the inside diameter of the outlet tube will be 8mm. The OD is 10mm.
I'm sure that Pikey is referring to the bore diameter of the valve itself, not the tube. The valve will be the flow limiter for pseudo-potstill operation.
DavidR wrote:Still_stirrin, the plan is to put a cap on the tee with a hole drilled in it and a thermometer in the hole sealed by a compression fitting or teflon tape. It's probably the more expensive option pikey, but half the fun is the build eh?
I figured. But an elbow could be drilled to accept a cork and thermometer just as easy, in fact, maybe even easier. A Tee will be at least 50% more expensive than an elbow and you'd have to buy a TC cap & clamp to close it. But...I guess it is your money...
DavidR wrote:Will be careful to avoid the smearing weir problem - good advice tks.
So, if you cut the TC gasket so it has a flat (shaped like a D opening), you could position the flat/weir on the bottom of the fitting joint, creating a pool with a calcuable volume. Complicated...maybe a little. But much more analytic....FWIW.
