How to cut copper pipe
eman33
Post by eman33 »
I have cut copper pipe with a pipe cutter before with good results but im having a hard time finding a pipe cutter for 2" pipe that doesnt cost an arm and a leg. I know you can cut with a hack saw but im worried my cuts wont be very square. Is there a saw blade for a chop saw that would but copper pipe well?
Also for my condenser jacket, I plan on running a piece of 1" all the way through some 2" to 1" reducers. Problem is, there is a stop inside the reducer that is gonna prevent the 1" from going all the way through. Is my best bet gonna be grinding that off with a dremal tool? Any other ideas are welcome.
Ftero
Post by Ftero »
If you are in the USA, you can buy a cheap plastic miter box like this:
A small round, or half-moon file will take the burrs off of the edges just fine.
Dnderhead
Post by Dnderhead »
Just a fine tooth blade will cut copper and aluminum ware safety glasses
and gloves ( just use cheep plywood blade) and yes file-grind out stops and some can just be forced threw
ol' rummie
Post by ol' rummie »
If you are using fittings over your 2" pipe ends, then it won't really matter if your hacksaw cuts aren't perfectly square. As for the reducers, I would (have) just use a round file to get rid of the stop, it takes a little longer , but those fittings ain't cheap.
runingkind
Post by runingkind »
You can put a plywood blade in your saw backwards to cut soft metal including copper.
bought wisdom don't come cheap,but it is a good teacher
Hawke
Post by Hawke »
You could also use a slide coupler. Lowes decription: Coupler Without Stop.
Slide it on the pipe to your cut line, tape the other end to the pipe. This will give you a good straight edge for the cuts. Could come in handy somewhere else in the build as well.
GingerBreadMan
Post by GingerBreadMan »
I use a round single cut bastard file to remove the stops in the copper tees. Takes about 2 minutes of filing. Recently I tried a dremel to do the same thing (just bought a dremel so I wanted to play). Took forever and still didn't get the job done. I ended up using the file for 30 seconds to finish the job right.
I started out with nothing, and I still have most of it left.
Dnderhead
Post by Dnderhead »
Use a bur in your dremel stones plug with soft mettle
