Honey Bear Bourbon
Re: Honey Bear Bourbon
Got full conversion on my starches to sugar on my 10 gallon batch of honey bear. I love this fucking recipe, my friends have told me that you can’t buy whiskey that food in the stores. Thank you SCD!
- ShineonCrazyDiamond
Many congrats to you, and you're welcome.
Shine on you crazy diamond."
Finally ran my first HBB spirit run. Looking at my notes this project has been in the making since April '21!
About 16L in the boiler. Collecting 250ml / jar. Started a little hot, first two jars came off at about 1.5L/hr, but I dialed it back and by the fourth I'd settled into a little under 1L/hr. I took a little taste at the start of jar 6 and the headsyness seemed to lessening somewhat. Did the same at the start of jar 7 and got a massive hit of sweetness and fruit. Went another few jars to be sure I was comfortably into the hearts and cranked up the power a little to get back up to around 1.25L/hr. Didn't touch the dial again until jar 21, when I cranked it up a notch before taking a taste and realising I was well into the tails. No noticeable alcohol, a bitterness and no interesting flavours lurking in the background. A few jars were swapped out a little late meaning that I had taken a little over 5L and my element gets exposed somewhere around 9L so I called it a day and powered down. Going to try blending tomorrow night if I've got time. Really looking forward to this one.
And there it is. Jar 6 had a bit too much heads to make the cut but jar 7 was a keeper. In the end Jars 7 to 15 were blended to make a white dog (of which I took 250ml and bottled it proofed down to 40%). I then added about 200ml of each jar from 16-19 which added some interesting flavours and a certain amount of funk. This gave me 3.1L at 66% to age on oak.
From my tasting, I could have kept going a little longer to pull dirty tails for the feints jar, but I don't think I missed anything by leaving them in the pot. This was surprisingly clean. It's not a neutral, but the nasty stuff seemed to stay in the early and late jars without contaminating the hearts. The white dog is quite flavourful. There's a certain amount of dark fruit, some sweetness. There was more fruit in the tails in the aging jar, but my wife wouldn't taste the sample blend because of the smell, so I'm hoping that some time on oak will lessen the smell without mangling the fruit.
Thanks for the recipe SOCD. It took a while but I finally got there.
- Location: Smack Dab in the Middle of God's country. Saskatchewan!
NormandieStill:
Was that smell throughout ALL the jars?
Or was the smell only in the tails that you added to the hearts body for aging?
Was that smell isolated enough you could have left it out completely?
Sounds like on your run, you took everything that could possibly add positive notes to your mix. So at least you won't be leaving out anything that was hiding!!!
Please update you experience after some oaking. I am very curious about the smell, and how the wood deals with it.
if you haven't thrown the rest out.... perhaps you could air one jar for many days and see if the smell leaves.
or try nuclear aging. Maybe some forced airing could remove it.
The fruit smell? It started coming in around jar 15 and seemed to intensify through jars 17 and 18 and then fade out again in 19. Over the top of this was a classic tailsy odour, wet card, wet carpet. There was a tiny little bit of it even in jar 15 which made the cut, but not enough to detract from the rest. In retrospect I might have done an even tighter cut for the white dog seeing as I was going to put the rest in to age.
I hesitated on jar 20 as there was some interesting mouthfeel in there, but nothing in either the nose or the palate to justify keeping it. I think I could probably have run on a little longer and gone further into the tails which is why it feels like I kept a lot. I'm not a big drinker so the white dog (and the other small batch spirits I've made so far) should keep me going for long enough for the rest to get some decent time on oak. I'm actually slightly under-oaking it (Based on Badmotivator's barrel surface area calculations - should be at about 270cm² and I'm at 200) because I don't want to overshoot and trample on some of those lighter flavours (I'm still new to this though so may just be talking out of my a...).
I will of course update the thread when I come to taste it.
Edit to add: I'm sipping on a glass of the white dog right now, and I would say that white, and with one day since it was proofed down, it's at least as good as the bottle of Makers Mark I bought as a reference for bourbon. The same level of complexity if not slightly more interesting, and with a similar burn although mine is at 40% and not the 45% of MM. I am now regretting having only pulled off 250ml and not 500ml.
- Oldvine Zin
Sipping a 5 year in barrel HBB and it's drinking well
OVZ
Stay safeOVZ
- Deplorable
That's impressive to stay out of something for 5 years.Oldvine Zin wrote: ↑Sun Jan 09, 2022 8:28 pm Sipping a 5 year in barrel HBB and it's drinking well5yoHBB.jpg
Stay safe
OVZ
Hell, I'm proud that some of what I made 14 months ago (before I filled my first barrel) still survives. But once you put in the work to build up some stock, I can see where it won't be long and I'll be in the same boat, sippin well aged spirits.
This recipe is on my to-do list.
- Oldvine Zin
So true when you start doing big batch ferments it doesn't take long to fill a 5 gallon barrel after barrel I have a few more aging but sad to say I've been lazy in stilling during this pandemic. Need to get the enthusiasm back up to fill a few moreDeplorable wrote: ↑Mon Jan 10, 2022 4:24 pmThat's impressive to stay out of something for 5 years.Oldvine Zin wrote: ↑Sun Jan 09, 2022 8:28 pm Sipping a 5 year in barrel HBB and it's drinking well5yoHBB.jpg
Stay safe
OVZ
Stay safe
OVZ
- Deplorable
You're so right OVZ.
I'm exploring options on a mash bill for another barrel fill. This time it'll be a new barrel, not a once used. So it's gotta be the right spirit.
I've got two barrels filled right now. Plus 4 of my 6 gallon jugs. And enough neutral to last me a good long while.
This current mash waiting to squeeze is something I'm chasing flavor on, so if it gives me what I want, I'll fill a new 5 gallon barrel next year with it.
Once those barrels start to mature, there's suddenly more liquor than you can drink.
Having a hard time finding this info in the thread, so apologies if this is redundant, but what other yeasts have people tried with this recipe? Im considering some ale yeast, but didn’t want to go too rogue. Thanks for any info!
At the top of the page, use google search for "ale yeast" and you'll find enough info to get the wheels turning.
― Charles Ives
― Charles Ives
Probably not much help compared to ale yeast, but I have a batch going with FermPro 921 (also their enzymes.)
Results pending, but it took off like a rocket and was already at 1.003 in three days. Still bubbling on day 5, albeit slowly.
I just did one with be256, very Fruity smelling mash, does not seem to have made it in to the barrel though. Maybe it will come back in a year...HItransplant wrote: ↑Wed Feb 09, 2022 5:20 pm Having a hard time finding this info in the thread, so apologies if this is redundant, but what other yeasts have people tried with this recipe? Im considering some ale yeast, but didn’t want to go too rogue. Thanks for any info!
Thanks for the suggestions. I think I’ll roll the dice with some US05.
So I see in this and in some other recipes (Sundae Chocolate Bourbon for example) that some of the malts are added with the corn to help keep things from becoming a gelatinous mess.
If you were using a high temp alpha-amylase enzyme would you still want to add malts in early? Or would you let the enzyme do its thing then add the malts at their normal gelling temps?
Thanks!
TwoSheds
Thanks!
TwoSheds
I believe he mentions in a comment post that he would put it in with the rest of the grains, and omit the rolled oats.
Buck Owens
Buck Owens
I just did a variant on this (a sort of halfway house between HBB and the Sundae Chocolate) using Chocolate Malt (barley). I didn't want to add it with the corn for fear of adding bitterness from the husks, so I stuck a small dose of HT AA in when I had broken up the dough balls. The corn thinned instantly and the chocolate malt went in with the rest of the malts.TwoSheds wrote: ↑Sun Feb 13, 2022 6:00 am So I see in this and in some other recipes (Sundae Chocolate Bourbon for example) that some of the malts are added with the corn to help keep things from becoming a gelatinous mess.
Thanks Normandie and Corn. I'm having fun venturing into the unknown but doing my best to avoid the stupid mistakes. Appreciate the feedback!
It's a fun hobby. Read, get ideas, research and make it, i find it very gratifying
Buck Owens
Buck Owens
- Deplorable
I just ordered the grains for a couple mashes of this. I like to scale up recipes to fit my fermenter so it's just easier to think in terms of percentages.
A few glasses into day drinkin' on a lazy Sunday afternoon my math for 25 gallons looks like this:
Corn Meal 65% (35#)
Honey malt 5% (2.5#)
White wheat malt 10% (5#)
Red wheat malt 10% (5#)
Pale malt 10% (#5)
Someone sober want to poke holes in that?
Corn Meal 65% (35#)
Pale malt 10% (#5)
Here’s my ratios for 25 gallons of water. It yielded me an SG of 1.063 fairly consistently using the large batch mashing protocol.
25lbs corn meal
2.5lbs honey malt
5 lbs white wheat malt
5 lbs red wheat malt
5 lbs briess pale ale malt
Looks like I’m a lot less on the corn ratio than you are, but this is mainly because I buy 50lb sacks of it and can split it between two batches and not have to store any left overs.
25lbs corn meal
2.5lbs honey malt
- Deplorable
Thanks. I think I was basing off of his cracked corn numbers, not cornmeal. That makes a significant difference in percentages and the statement about
Sometimes I use whole corn milled, and other times I use BRM corn meal, but my efficiency with either is about the same. I'll just do like you did and just multiply the recipe by 5
Ah good catch on the corn meal vs cracked corn. I’ve only used fine corn meal for this recipe. Works great for my process!
Hey all, just stripped my first HBB last night and doing the spirit run now. I’m already planning my next run and thought, I don’t see anyone mentioning using backset with this recipe.
Is there a reason? Is it geared to folks who may not have a run in already? Is it just a kinder, gentler recipe that stands better without?
I had a spare 5 gallon bucket lying around so I filled it up for future use anyway, but wondering what @ShineonCrazyDiamond or others think.
Great smells and tastes came off the stripping run. Looking forward to the end product!
Thanks.
TwoSheds
Thanks.
TwoSheds
I did not go back a read the posts but looking at the original recipe I see know reason you could not use back set. I use a backset on my corn/rye bourbon. I follow the steps on 2+ generations of UJ but add extra corn and rye.
- Deplorable
I just added in the 15 pounds of malted grains on a 25 gallon mash of this recipe for my first foray into wheated bourbon. I'm down to about 3 fifths of CROW still aging on oak fingers from a year ago, and I'm looking forward to seeing what all the hype is about. It'll be nice to add another flavor to the cupboard with my rye whiskeys, corn whiskey, and single malt.
I have enough small grains to make another batch once the fermenter is emptied.
- Deplorable
Well about 28 hours after I doughed in I pitched a healthy starter of US-05. I'm a little disappointed in my efficiency on this mash, as I only got a 1.062 SG. I'm not 100% sure of the accuracy of the hydrometer I used, since my old one finally met its fate. I've only used this one once before. I set aside a small sample of the wort and ordered a refractometer to check against my hydrometer.
My grain ratio was a tad over 2#/Gal since I ran out of space in my fermenter at 21.5 gallons, so I was expecting closer to 1.07 but this will still make plenty of whiskey.
Isn't that sg about average for those ratios? That's where I'm always at at 2# per gl.
My hbb was right there as well as the sugar head i did with the spent grains
Buck Owens
Buck Owens
