Measuring pH: Strips or meters?
Single Malt Yinzer
Post by Single Malt Yinzer »
My last batch of pH strips were a bust as they seemed highly inaccurate. It seems meters are pricey if they are accurate. I really would love a cheapish meter (less than $50) that works well.
So what ya got? What ya recommend?
kiwi Bruce
Re: Measuring pH: Strips or meters?
Post by kiwi Bruce »
The Homebrew stores sell a test kit for testing the acidity in wine. They are OK for accuracy , easy to use...defiantly better that pH papers and not to pricey...you should be able to find one for under ten bucks.
(It breaks my heart, but) I've finally decided my future lies
Beyond the yellow brick road...from Elton John
Shine0n
Post by Shine0n »
My meter is a cheapo but seems to be ok as when I used it on my dunder pit after the addition of lime it said 5.5 and the next day the pellicle returned on the pit.
I've only used it 3 times and was on the dunder pits as I've not had time to make a wash lately. but all 3 times was the same result.
I got it off amazon
I used the strips before on mashes and got close enough to know if it was low, did not work on rum ferments though.
Strips are cheap and accurate enough for clear washes . Universal indicator solution is also a good choice here.
But for Rum washes I would recommend a meter as the dark brown colour of Rum washes makes it difficult for strips or indicator that rely on colour .
If you use a meter , you must wash it immediately after testing and preferably store it in the 4M Potassium chloride solution to maintain its longevity .Never use distilled water to wash and store .
However expect all meters to only last a few years and become slower to respond with age .
Meters are cheap enough these days that even after a few years you will get your money back .
But , whether you use strips or meters , don't get so bogged down by pH readings that it sends you into a spin .
Single Malt Yinzer
Thanks everyone. I'm looking at the two meters here:
$16 basic version, no thrills:
https://www.amazon.com/Jellas-Household ... B00YBUH4RC" onclick="window.open(this.href);return false;" rel="nofollow
$46 Upgraded with temp, includes pH solutions for calibration:
https://www.amazon.com/Apera-Instrument ... B01ENFOHN8" onclick="window.open(this.href);return false;" rel="nofollow
YummyRum - This looks like what you were speaking about. Do you need to dry or clean the electrodes before use or can you use it right away?
https://www.amazon.com/Milwaukee-Instru ... B002P35Y6U" onclick="window.open(this.href);return false;" rel="nofollow
OtisT
Post by OtisT »
I have not had luck getting consistent reading with two different meters. Seems to never settle on a PH level, and is not consistent. I gave up on the meters and went back to strips. They are cheep enough I can use a few to double check things.
All that said, there are folks smarter than me who seem to get the meters to work and like them, so who knows.
Shine0n
Post by Shine0n »
I only use strips on clear washes and it's good enough for that, if in doubt use a buffer to insure that drop is minimal at best and go even further, get some picking lime to raise just in case.
bluefish_dist
Post by bluefish_dist »
Meter and get with temperature compensation. Makes life much easier. If you can't afford one, stay with strips instead of wasting money on one without it.
Formerly
Dsp-CO-20051
Single Malt Yinzer wrote:P
Not exactly sure what that is but I'd be pretty sure its the stuff . 4M KCl ( Potassium Chloride solution of 4 molarity ) is the common stuff and there is not much variation between probes .
Always a good idea to give them a rinse with fresh water between use . By fresh I mean tap water is usually good enough . Especially if you have been measuring really high or low pH stuff . Most tap water is reasonably nuetral especially if it comes from a municiple supply .
Most pH meters need calibrating every 10-20 odd measures . You need to get some pH buffer solution to calibrate . Some metes nust have a single point calibration at pH 7 . Some have a two point calibration at say 4 and 10 while others have three point at 4 , 7 and 10 . .... we really don't need to be that anal :ebiggrin:
texasspur21
Post by texasspur21 »
I think strips work better. The tempurature affects the results and temps are always changing. Plus, if you can get somewhere near 5.2, you’re good, doesn’t need to be perfect.
Reverend Newer
Post by Reverend Newer »
Beware that pH strips do age and oxidize over time once the foil pack is opened, skewing their measuring ability. Keep pH strips away from heat, light and humidity. One thing that helps with strips is to only wet the tip and let the moisture draw up into the strip, rather than dunking half the strip which causes more bleeding of colors.
The pH testing drops work a bit better for me than trying to read the bleeding colors of the test strips. The pH testing solution must also be kept away from heat and light or it will degrade and give false readings. Just add 3 drops or so to a little test tube of wash, shake, then compare it to the color chart.
A digital pH meter is most accurate in my opinion but they need to be maintained by keeping the electrode in storage solution and calibrated occasionally depending on amount of use. BlueLab pH meters are pricey but they automatically adjust for temperature and will last a few years if properly maintained.
Never store your pH meter in reverse osmosis or distilled water as doing so will remove ions from the probe rendering it useless.
spiritually taxed circa 1791
UrToopid
Post by UrToopid »
Single Malt Yinzer wrote:My last batch of pH strips were a bust as they seemed highly inaccurate. It seems meters are pricey if they are accurate. I really would love a cheapish meter (less than $50) that works well.
You get what you pay for when it comes to information gathering (data).
This cannot be more true than in the case of a measurement. I am an Instrumentation and Electrical (I&E) tech. I calibrate instruments including pH meters for the petrochemical industry daily. A decent pH meter is worth its weight in gold and way more accurate than strips or test kits. You don’t need anything with an accuracy greater than 1%. (You pay a lot more for higher accuracy. It’s like buying a Lamborghini to run at the local dirt track)This means that it will read within one decimal point (tenths)when calibrated using a 4.01 and 7.01 buffer. Most brewer supply stores sell these, and the one-shot buffer packets really cheap. A decent meter will run you between $60-$100. Less than that and you are shooting dice. I went through some headaches using the $20 meters they sell at our local brew shop. After the second cheap meter crapped out within weeks of buying it, I decided to go a little higher. I settled on a $70 probe made by Hanna Instruments with an integral digital display and have had it for over two years now. The trick with any bulb type pH probe is to store it in a slightly acidic buffer (I mix the 4.01 with the 7.01) apx. 6.0-6.5. This keeps proteins from building up on the glass bulb. It is necessary to use new buffer solutions EVERY time you re-calibrate. If you have a larger supply, that is fine, pour out just what you need for each buffer and toss it when you are done. It is also VERY important to not dip your probe directly from one buffer to the next. A few drops of the 7.01 buffer in your probe tip can quickly contaminate your 4.01 and vise versa. It is strongly recommended to rinse the probe in DI water and shake off (don’t wipe the probe)between bufffers.. this will insure accurate and trustworthy readings.
Happy measurements!
masonsjax
Post by masonsjax »
https://www.homebrewtalk.com/forum/inde ... er.446437/" onclick="window.open(this.href);return false;" rel="nofollow
Pay attention to anything that users ajdelange or mabrungard have to say, they are very knowledgeable professionals.
Kai Troester's site also has some buying info:
http://braukaiser.com/wiki/index.php?ti ... ying_Guide" onclick="window.open(this.href);return false;" rel="nofollow
Single Malt Yinzer
Thanks guys this is the type of info I needed. I'll be getting decent meter for myself for Xmas.
jonnys_spirit
Post by jonnys_spirit »
I use a couple meters that I purchased for winemaking. One is nice and cost a couple hundred dollars. It measures pH, SO2, and TA. The other is a cheap $15 meter from amazon. Calibration standards and storage medium plus some other titration chemicals. The needs for measuring pH in mashes, backset, etc appear fairly simple. I’ll use both meters and compare for reference. The better one measures iit to two decimal places and the other to a single decimal place. Useful tools for troubleshooting and two devices gives you some indication of error.
-j
nathar
Post by nathar »
I bought a pH meter from Thermoworks because I've had good luck with the thermometers I have purchased from them. Piece of Chinese junk only lasted one year. Paid $50 for it.
I went to Amazon and thought I found a good one. It had 283 5-star ratings....and they were all posted on the same day. You can't trust these ratings anymore. Amazon has allowed for too much hanky-panky from it's sellers.
Every single litmus paper, test strip, and pH meter, regardless of price, had significant numbers of 1-star "it's crap," "doesn't work" reviews. What can you do?
