14 gallon copper double boiler build
Hilltop
Post by Hilltop »
Good evening, I recently saw an old copper double boiler on Craigslist and got it for 75 bucks. It's an old boiler, this design fits on both eyes of a stove top and I knew this would be a perfect still for an RV " Mancave- Brew House" out back.
So I started out planning and sourcing copper, no easy task it seems, I had to trade a half gallon of my best for a piece of two inch copper. The boiler by my measurements is roughly 13.885 us gallons. I am restricted horribly by the low ceiling in an RV but I started out by cutting a 1 3/4 hole in the lid and welding a two inch coupling and broke out my measuring tape.
I wanted a gauge on this rig as I'm using it to steam cook grain, I built a stainless 7.75 gallon keg, and used unions to go from steam cooker to strip, to thumper so I can turn this rig multiple directions, I stuck to my old tried and true cardboard gasket cut with jig saw wrapped in Teflon. The lid has a lip that goes down into the boiler a full inch and barely leakes a drop of steam without the gasket.
The only problem so far is I limited myself to a half inch steam pipe and I'm having to cook a long time to get up to 200 degrees, I will be fixing that directly. The thunmper was made using a copper flange off flea bay, I had to get a donkey dick on an end grinder inside my two inch to get it to fit.
I welded a 1 inch Teflon seat ball valve on front for a boiler drain, I'm stripping corn- wheat malt and oat mash now , so I will hook up thumper tommorrow and take some more pics, sorry for the crappy resolution.
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
This topic has 8 more replies
Register Login
