I wanted to add some spices to a fairly bland (all 2row grain),
I added 1 pod from a star anise, 1 all spice berry, 10 coriander, & 1 clove, each into their own 250ml jar, just so I can an idea of how the flavors and aromas will come across before creating a mix.
It's only been 2 days but there is zero color, flavor, or aroma from any of them. I am wondering if grinding the spices will make a difference (other than needing to be filtered in the end instead of just removing the solids)
Anyone had much luck spicing up a whiskey? If so I would really appreciate recipe/technique.
Cheers & Thank You in advance
Spices - whole or ground ?
- Expat
Re: Spices - whole or ground ?
If you grind the anise, its all you're going to taste
Powerful stuff.
For the others, generally a course chop works best as you won't end up having to paper filter you spirits to get the dust out.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
