Brix Readings, and What They Tell Us
Brix – A unit of measure used in the refractometer. When the Brix reading is divided by 2 it will be equal to the percent of crude sucrose in the plant tissue.
Refractometer – A device used to measure the refractive index of plant juices in order to determine the mineral/sugar ratio of the plant cell protoplasm.
Refractive Index of Crop juices are calibrated in percent sucrose or degree Brix.
During the growing season it is possible to check a plant for percent sucrose. A refractometer is easy to use. You will need something like a garlic squeezer for juicing the plant sample. To make a reading, place 2 to 3 drops of the liquid sample on the prism surface, close the cover and point toward any light source. Focus the eyepiece by turning the ring to the right or left. Locate the point on the graduated scale where the light and dark field meet. Read the percent sucrose (solid content on the scale).
The refractometer measures in units called Brix. The Brix equals to percent crude carbohydrate per 100 pounds of juice. The higher the carbohydrate in the plant juice the higher the mineral content of the plant, the oil content of the plant, and the protein quality of the plant.
For example, if you were to have 100 pounds of alfalfa that has a Brix reading of 15 it would mean that there would be 15 pounds of crude carbohydrates if the alfalfa was juiced and dried to 0 percent moisture. By dividing 15 by 2 it tells us that the actual amount of simple sugar would be equal to 7.5 pounds.
Crops with higher refractive index will have a higher sugar content, higher protein content, higher mineral content and a greater specific gravity or density. This adds up to a sweeter tasting, more mineral nutritious feed with lower nitrates and water content and better storage attributes.
Crops with higher Brix will produce more alcohol from fermented sugars and be more resistant to insects, thus resulting in decreased insecticide usage. For insect resistance, maintain a Brix of 12 or higher in the juice of the leaves of most plants. Crops with a higher solids content will have a lower freezing point and therefore be less prone to frost damage.
Brix readings can also indicate soil fertility needs. If soil nutrients are in the best balance and are made available (by microbes) upon demand by plants, readings will be higher.
You will find that when the phosphate levels in the soil are not up to what they should be, the sugar in the plants will vary from the bottom of the plant to the top. In other words, the Brix reading at the bottom of the plant will be higher than the top of the plant. The better the phosphate levels in ratio to potassium the more even the Brix reading will be all over the plant. Also the better the phosphate levels in ratio to potassium the less fluctuation there will be in the brix reading in any given 24 hour period.
You will also note that when you are looking into a refractometer you will sometimes be able to see a very sharp line which is very easy to read, while at other times it may be a very hazy line and not well demarcated and so difficult to read. The very sharp and dark and easy to read line means the crop is lower in calcium and higher in acid. A very diffuse and hard to read line tells one that the calcium is higher and the acid is lower in the plant. This is why a lower Brix reading on a plant will actually taste sweeter when there is high calcium than one that may have a little higher Brix reading and a low calcium. The available soluble sugar is what gives taste and sweetness to food. The more calcium in the crop along with the sugar, the sweeter the taste even though the Brix reading will be the same on two samples.
Edit looks like original info is gone . heres a link https://www.bing.com/images/search?q=br ... RE&first=1
Brix of fruits /veggies
- Tater
Tim Julius
Re: Brix of fruits /veggies
Brix readings provide valuable insights into plant health by measuring sugar and mineral content through a refractometer. These readings can help indicate the quality of crops, soil fertility, and even resistance to insects and environmental stress. Regular monitoring and maintaining higher Brix levels can improve plant quality, taste, and resilience, making it a crucial tool for optimizing agricultural practices.
- banijarakija
This is fantastic information on Brix. I recently got a refractometer and used it for the first time on the pears we use for distilling. I've also been reading how Brix levels indicate insect resistance because their digestive systems cannot digest the sugars like our stomachs can, and that higher brix=more resistance. I was thrilled to see brix of 17-19 in our pears. My biggest regret is not having this information from past years.
Thanks for the info on calcium as well.
