Hi
I have been a brazer for over 7 yrs (working with silver wire and steel tubues)and thought that I would try and build a still head for a small still for redistilling of brandy.
What wire would work best.
For torch what works good? (I allwas used two torches to heat parts up to hand braze)
Thanks for any help given
silver wire
Re: silver wire
We should be asking you.I have been a brazer for over 7 yrs (working with silver wire and steel tubues)
Fire is the devil’s only friend - Don McLean
Jump in where you can and hang on - Brisco Darling
Re: silver wire
I think brazing and soldering are two differnt things not a plumer.
I just dont want to use the wrong wire
And i use a much higher heat than what is reqired some one must have a prefence.
Happy Distilling
Happy Distilling
Re: silver wire
Preferably silver/tin or copper/tin without other metals/minerals added. Have seen 'lead free' solders with antimony or selinium added. May be safe for drinking water but, how does it react with hot alcohol vapors?
Re: silver wire
Ok
Thanks for the reply, do you have a prefernce for torch heads?
Would like to try a water jacket pot still for redistilling some brandy.
Thanks agian
Thanks agian
Re: silver wire
I just stumbled across your post.
If you're still looking for an answer on brazing filler, let me know. I'm a CWI, with tons of soldering, brazing, braze-welding, & welding experience.
