Fruit Fly Control
- Fiddleford
Fruit Fly Control
Hello I haven't yet to find a topic on fruit fly control.
I thought it would be a good ideal for all of us to share our methods of fruit fly control, I have my own but it requires a watchful eye and maintenance.
My method is to clean a jar really good then put a tsp of molasses and yeast in the jar and sit it open in a high fruit fly location, typically around my mashes or dunder pits. after a bit of waiting I check the jars and if they have a hefty or any amount of the pesky punks in there I'll screw the lid on and run the jar under searing water, which kills them effectively then I place the jar back in the same place till I get little to no result. only problem is it takes a long time to get em to go in there and that's all I have a problem with.
If you have any additions to the methods or your own methods pleas share I and I'm sure others will appreciate to hear of them.
- cuginosgrizzo
Re: Fruit Fly Control
I have my method too. It's time consuming but works very well. Take any hemorrhoid cream of your choice, and spread it carefully on the backs of the little pests. They die almost instantly! I have tried with toothpaste also, but it does not seem to work as well.
- der wo
I make a mix from water, vinegar, honey and soap. Vinegar is extremely attractant for them. I don't now why honey helps. Soap reduces the suface tension.
Edit:...but will try out the hemorrhoid cream next time. Seems to be more respectful to those animals.
- Swedish Pride
just a shot glass of apple vinegar or some or the fermenting wash, a drop of washing up liquid, cover in cling film and pierce a few hole in the film, just set and forget. change weekly if needed
Don't be a dick
- Fiddleford
der wo. I think that mixture would attract critters for miles around. I don't use molasses for the magical reasons of its being what it is, I use it because its what I got on hand, I will have to put honey aside next time I make mead.
- Fiddleford
Swedish Pride. I have done that and it works just fine, but the boss of the household doesn't much appreciate shot glasses with questionable fluids in them, they much prefer jar's with questionable fluids in them because I already got a million of them.
- Truckinbutch
Dawn dish soap on top of cider vinegar , sticky fly strips , and a bug zapper used in conjunction .
A shotglass full of fruity heads
- Truckinbutch
There is also the BUG-A-SALT pump shotgun that uses table salt (80 shots per tbs ) for close range interdiction of the crafty ones . I have a ball with mine . Google it .
- cranky
That's the method I use too, apple cider vinegar, drop of soap in a bowl covered in cling wrap with some holes poked in it. One note of caution, don't use apple scented soap, they won't go for it.Swedish Pride wrote:just a shot glass of apple vinegar or some or the fermenting wash, a drop of washing up liquid, cover in cling film and pierce a few hole in the film, just set and forget. change weekly if needed
If I have a lot of them I will wait til they are asleep then get the shop vac and suck them up, works real well.
They are actually completely suicidal for an apple ferment bubbling through an air lock full of heads.
They also like those hanging fly strips if you get inundated like I did last summer.
The bait jars were filling quicker than their breeding.
Little buggers were so happy being stuck to the strips, they would actually die all glued together while humping.
I nuke my "distillery" with germicidal UVC and ozone every now and then. This pretty much wipes out anything living in the entire room. An extremely powerful stuff and no chemicals involved. Sometimes I'm thinking where I'm getting these wonderful ideas all the time. I guess you give the hardest job to the laziest person and this is what happens.
I've tried the vinegar and it did just ok, now I take an apple (store bought) after peeling it for the youngin put the peels in a mason jar and cling wrap it with holes poked in the top, change weekly and they stay under control.
A year ago I had an infestation of these critters in my kitchen. I tried the vinegar trick and it didn't work. I put an inch of red wine in a jar covered with foil and a few toothpick holes through the foil. Drowned dozens of them. Figured my bugs were lushes not sour pusses. But I'm not sure its even possible to avoid attracting them when working outside in my garage - so I just cover everything with paper towels held in place with rubber bands - this keeps them from drinking too much of my product. Angels I don't minds - bugs are a different story.
Pure cheap wine vinegar in a trap, i.e. a jar with a plastic foil lid on which I make holes with a fork (or a toothpick).
The pure vinegar makes a strong odour all over the kitchen. The pests cannot resist. I cannot resist as well, after a few days.
Do you filter out the bugs before you drink it?Birrofilo wrote:Pure cheap wine vinegar in a trap, i.e. a jar with a plastic foil lid on which I make holes with a fork (or a toothpick).
I used to make yellow jacket traps out of gallon milk jugs and pvc pipe. they could probably be
down sized for fruit flys. the yellow jacket size uses 3/4" or 1" pvc pipe stuck through the milk
jug. the pipe needs to be long enough to miter both ends, so you have a long side and a short side,
the long side is the bottom. grind a good sized hole in the bottom, the miters are landing pads.
for fruit flys 1/2" pvc or even a drinking straw would work in almost any plastic bottle.
