Hot dammit
Alchemist75
Hot dammit
Post by Alchemist75 »
Did my spirit run today but I had to stop because I noticed I was getting cloudy product well into hearts. It's copper smut in there. I noticed when I was collecting early heads that there was a brown deposit showing up on the inside of my steel funnel but it cleared up about 400 ml in. When I stopped the run I took a sample of the new make and set it afire on a spoon. Sure enough, it left a brown deposit behind. I took a little taste and it left a lingering bitterness on the back of my tongue. I cleaned all the plumbing out some way as I always do before I run but apparently I either missed a spot or something is off somewhere. I'll re run everything tomorrow but that's really frustrating.
SOLVE ET COAGULA, ET HABEBIS MAGISTERIUM
fizzix
Re: Hot dammit
Post by fizzix »
Brown has me concerned on a spirit run.
Sounds like hot patina. Maybe just too hot, I'm guessing.
Alchemist75
Re: Hot dammit
I was running her as slow and low as ever, keeping the off take nice and easy. When I broke her down I noticed a distinct deposit of verdigrease where the cooled liquid flows down and out of the condenser. Not clear what happened but everybody is getting a good hot bath in vinegar, salt and citric acid tonight. I'll put all the new make back in with the remaining low wines and run it again tomorrow. Typically the only time I've ever seen something like this is when I strip on dirty gear. Just a waste of 4 good hours. Shoot.
Re: Hot dammit
Alchemist75 wrote:When I stopped the run I took a sample of the new make and set it afire on a spoon. Sure enough, it left a brown deposit behind. I took a little taste and it left a lingering bitterness on the back of my tongue.
That sounds a bit like caramel. Could there have been any residual sugar in the charge?
Alchemist75
Re: Hot dammit
Does sugar come through on a run? My product is usually pretty sweet, sugary almost. Granted it was obvious upon examining my gear that some corrosion had occurred which could have resulted from some acidity in the low wines. Chris, this was that batch I made with the maize flakes that I asked folks to vote on. Hopefully I don't lose anything by distilling it one more time.
Re: Hot dammit
Alchemist75 wrote:Does sugar come through on a run?
It shouldn't, but if it might if the riser is narrow and stuffed with enough scrubbies for vapor speed to prevent puke from falling back into the boiler.
Pikey
Re: Hot dammit
Post by Pikey »
" Cherchez la merde" ! :wink:
[or is it "le merde" ? :) ]
Fiddleford
Re: Hot dammit
Post by Fiddleford »
Pikey wrote:" Cherchez la merde" ! :wink:
Don't know what that means but I recognized merde from a langue my friend spoke. Shit?
Rye whisky rye whisky oh dont let me down
Gunna have me a drink then gambol around
Here's some fiddle music
Pt1
Pt2
Pikey
Re: Hot dammit
Post by Pikey »
Correct - the rest means "Look for..."
Somewhere - something is mucky ! imho of course :)
Fiddleford
Re: Hot dammit
I would suggest to take something that reacts with copper and add it to the brown gunk, if Alchemist isolated it that is.
Pt1
Pt2
Alchemist75
Re: Hot dammit
I did, I tried adding vinegar to some of it and let it set up over night. It didn't go blue. I find the puking scenario unlikely as the boiler was only half full. I'm wondering if it isn't rust. Very occasionally I've found a small piece of scrubby with traces of rust on them. Knowing that stainless steel isn't truly rust resistant this doesn't surprise me and I do put a small piece in my condenser. The presence of verdigrease in the condenser still has me thinking it's copper however.
Alchemist75
Re: Hot dammit
Gonna set up and re run here in a bit. The parts look like brand new, shiny, bright copper, even the outsides. I stay on top of cleaning but I guess sometimes you gotta go the extra mile with it. Nary a trace of patina inside the plumbing.
Alchemist75
Re: Hot dammit
One thing I did differently this time is that I alcohol dried the parts with 90+ ethanol rather than using foreshots and it did a much better job of removing trace amounts of moisture. I notice when I dry with foreshots that it'll leave a patina behind that then has to be removed prior to running. I haven't proofed my foreshots but I suspect they're in the 60-70g% range. Too much moisture in em' to do the job right.
Alchemist75
Re: Hot dammit
Yeah, it had to be the copper, it's running off crystal clear now.
Timoun222
Re: Hot dammit
Post by Timoun222 »
Hello,
I had a dirty brown deposit in the filter of the funnel when I was collecting the end of a first run (doing double distillation with a pot still). I’ve noticed that before and it’s always at the end of the distillation. I do pure sugar cane distillation. Check the picture.
Is it because of the temperature? Problem of cleaning? Cooling? Residuals sugars?
Windy City
Re: Hot dammit
Post by Windy City »
Alchemist75 wrote: ↑Tue Aug 28, 2018 9:15 am One thing I did differently this time is that I alcohol dried the parts with 90+ ethanol rather than using foreshots and it did a much better job of removing trace amounts of moisture. I notice when I dry with foreshots that it'll leave a patina behind that then has to be removed prior to running. I haven't proofed my foreshots but I suspect they're in the 60-70g% range. Too much moisture in em' to do the job right.
You should leave the patina, you really don't want shiny copper on the inside of your still.
It will bring over a metallic taste to your distillate.
When I first started I would regularly run citric acid through my clean in place but learned rather quickly that it wasn't needed and was actually detrimental to the quality of my product. Now I only deep clean once a year and follow up with a stripping run to "season" the inside of the still.
Secale
Re: Hot dammit
Post by Secale »
Never hurts allow to a cloudy liquid sit for a few weeks or more so the most microscopic particles can settle.
Siphon the clear liquid without disturbing the bottom layer.
PalCabral
Re: Hot dammit
Post by PalCabral »
Timoun222 wrote: ↑Mon Mar 23, 2026 3:17 am Hello,
That looks like melted caramel and quite disgusting, Timoun222. I have no idea what it is. What kind of product condenser do you have? For something to travel from the boiler with the vapors and the condense into that stuff coming off the spout it quite wild. How long since you cleaned your condenser?
Windy City
Re: Hot dammit
It looks like it puked. Was this on the stripping run?
Timoun222
Re: Hot dammit
Post by Timoun222 »
Hello,
My Pot Still can’t puke because it has a big onion shaped head on top of the boiler. I have a copper condenser but I do have some problems of cooling. The water at the end of the distillation goes out very hot of the condenser.
This orange deposit appears normally at the end of the stripping run when it starts to be very oily (fusels oil).
I will today clean the condenser with hot water, salt and vinegar and see if it’s better.
Re: Hot dammit
Timoun222 wrote: ↑Fri Mar 27, 2026 5:21 pm Hello,
Foam-ups don’t care whats between the boiler and the spout .
Try using some vege oil or butter . Sometimes they work , sometimes they don’t .
I can’t be stuffed with foam ups now . I use Silicone anti foam . Stops foam ups and puke dead .
Timoun222
Re: Hot dammit
Post by Timoun222 »
I’ve cleaned the condenser and the boiler with a 50/50 solution vinegar and hot water. So far so good. I will check during my next stripping run if I still have this dirty deposit coming with the tails…
fzbwfk9r
Location: Smack Dab in the Middle of God's country. Saskatchewan!
Re: Hot dammit
Post by fzbwfk9r »
Hey Yummy, got a link to that anti-foam product?
I'm interested in reading up on it.
Re: Hot dammit
fzbwfk9r wrote: ↑Sat Mar 28, 2026 8:52 pm Hey Yummy, got a link to that anti-foam product?
Sometimes I get this one.
https://www.homebrewshop.co.nz/product/ ... nditioner/
Or this one
https://www.borderbrewing.com.au/produc ... SjyyhhSWuk
Both are the same stuff AFAIK .I just grab one from my Homebrewshop . The hype says they release CO2 but they are really surfactants.
I think there is a Fermcap version in USA
Also do a search on “simethicone anti foaming for distilling”
PalCabral
Re: Hot dammit
Post by PalCabral »
I use a big onion too but that will not stop foam ups and prevent pukes. Yes, it does have an effect but when I am running malted wheat and barley, I need to keep an eye on the glass diopter below the onion just in case. I've used butter but it's no insurance either. Maybe I'll give the distilling conditioner a go.
fzbwfk9r
Re: Hot dammit
Post by fzbwfk9r »
Yummyrum wrote: ↑Sat Mar 28, 2026 11:34 pm Sometimes I get this one......
Thanks Yummyrum, for the info!
Timoun222
Re: Hot dammit
Post by Timoun222 »
Hey!
A quick update:
After a good cleaning, I could get rid of the brown deposit that I had during the end of my stripping run.
I think my condenser was just dirty inside because of my previous distillation. I did some Gin before so maybe that didn’t help it too.
PalCabral
Re: Hot dammit
Post by PalCabral »
Yummyrum wrote: ↑Sat Mar 28, 2026 11:34 pm Or this one
Thanks for this tip, Yummy. I've been using this one for the last couple of runs. Usually, I get a lot of foam-ups when running wheat but three caps of this stuff and it's been smooth sailing.
Re: Hot dammit
bluc just gave me a link to this stuff .
Not sure if its available outside of Aussie , but the price shits all over the little HBS 50ml bottles ……Thanks bluc :thumbup:
https://beerco.com.au/products/foamstop-antifoam
PalCabral
Re: Hot dammit
Post by PalCabral »
Couldn't find it in Sweden when I searched for it. The manufacturer is Aussie, Flexichem, so it may well be a product only available down under. But there are probably very similar silicone based products in EU. Vinoferm Anti-Foam, which pops up everywhere when I search for the above, is also silicone based. But Vinoferm is expensive: 10 USD for 100ml.
