| Primary | Secondary | Tertiary | Mix BP °C | P BP °C | S BP °C | T BP °C | P mass % | S mass % | T mass % | Notes |
| Acetaldehyde | 21 | 21 | 100 | No water azeotrope | ||||||
| Ethyl formate | Methanol | 51 | 54.1 | 64.7 | 84 | 16 | ||||
| Methyl Acetate | Methanol | 53.8 | 57 | 64.7 | 81.3 | 18.7 | ||||
| Acetone | Methanol | 55.7 | 56.5 | 64.7 | 87.9 | 12.1 | ||||
| Methyl Acetate | Water | 56.1 | 57 | 100 | 95 | 5 | ||||
| Acetone | 56.5 | 56.5 | 100 | No water azeotrope | ||||||
| Methyl Acetate | Ethanol | 56.9 | 57 | 78.44 | 97 | 3 | ||||
| Ethyl Acetate | Methanol | 62.3 | 77.1 | 64.7 | 56 | 44 | ||||
| Methanol | Isopropanol | 64 | 64.7 | 82.5 | 80 | 20 | ||||
| Methanol | 64.7 | 64.7 | 100 | No water azeotrope | ||||||
| Ethyl Acetate | Water | 70.4 | 77.1 | 100 | 91.9 | 8.1 | ||||
| Ethyl Acetate | Ethanol | 71.8 | 77.1 | 78.44 | 69.2 | 30.8 | ||||
| Diacetyl | Ethanol | 73.9 | 88 | 78.44 | 53 | 47 | ||||
| Isopropyl acetate | Isopropanol | Water | 75.5 | 101.6 | 82.5 | 100 | 76 | 13 | 11 | Ternary azeotrope |
| Ethanol | isopropyl acetate | 76.8 | 78.44 | 88.4 | 53 | 47 | ||||
| Ethanol | Methyl butyrate | Water | 77.62 | 78.44 | 102.34 | 100 | 56.63 | 34.88 | 8.49 | Ternary azeotrope |
| Ethanol | Methyl butyrate | 78.13 | 78.44 | 102.34 | 80.78 | 19.22 | ||||
| Ethanol | Water | 78.29 | 78.44 | 100 | 95.68 | 4.32 | ||||
| Diacetyl | Water | 78.5 | 88 | 100 | 89.29 | 10.71 | ||||
| Isopropanol | Water | 80.4 | 82.5 | 100 | 87.7 | 12.3 | ||||
| N-Propyl acetate | Water | Propanol | 82.2 | 101.6 | 100 | 97.3 | 59.5 | 21 | 19.5 | Ternary azeotrope |
| N-Propyl acetate | Water | 82.4 | 101.6 | 100 | 86 | 14 | ||||
| Methyl butyrate | Water | 84.77 | 102.34 | 100 | 82.11 | 17.89 | ||||
| Propanol | Water | 88.24 | 97.3 | 100 | 71.03 | 28.97 | ||||
| Isobutanol | Water | 90 | 108 | 100 | 70 | 30 | ||||
| Isobutyl acetate | Water | 90.26 | 118.04 | 100 | 75.6 | 24.4 | ||||
| N-Butyl acetate | Water | N-Butanol | 90.6 | 125.94 | 100 | 117.8 | 63 | 29 | 8 | Ternary azeotrope |
| N-Butyl acetate | Water | 90.7 | 125.94 | 100 | 72.9 | 27.1 | ||||
| Ethyl butyrate | Water | 91.4 | 120.54 | 100 | 73.24 | 26.76 | ||||
| Butanol | Water | 92.4 | 117.8 | 100 | 55.5 | 44.5 | ||||
| N-Butyl acetate | Water | 92.98 | 125.94 | 100 | 69 | 31 | ||||
| Water | Isoamyl alcohol | Isoamyl acetate | 93.6 | 100 | 130.54 | 142 | 44.8 | 31.2 | 24 | Ternary azeotrope |
| Propyl butyrate | Water | 94.91 | 142.74 | 100 | 61.74 | 38.26 | ||||
| Isoamyl alcohol | Water | 95.31 | 130.54 | 100 | 51.33 | 48.67 | ||||
| Water | Iso-butyric acid | 99.3 | 100 | 154.5 | 79 | 21 | ||||
| Water | Butyric acid | 99.94 | 100 | 163.5 | 81.6 | 18.4 | ||||
| Water | Propionic acid | 99.98 | 100 | 141.1 | 82.3 | 17.7 | ||||
| Formic acid | Water | 107.3 | 100.8 | 100 | 77.5 | 22.5 | Negative azeotrope | |||
| Acetic acid | 118.1 | 118.1 | 100 | No water azeotrope |
References:
http://vle-calc.com/azeotrope.html" onclick="window.open(this.href);return false;" rel="nofollow Azeotrope database for organic solvent mixtures
https://en.wikipedia.org/wiki/Azeotrope_tables" onclick="window.open(this.href);return false;" rel="nofollow
https://chestofbooks.com/science/chemis ... tures.html" onclick="window.open(this.href);return false;" rel="nofollow
http://biopent.uv.es/~roberto/Docencia2 ... _35_86.pdf" onclick="window.open(this.href);return false;" rel="nofollow
THE BREAKING OF TERNARY ACETATE-ALCOHOL-WATER AZEOTROPES BY EXTRACTIVE DISTILLATION. LLOYD BERG & AN-I YEH
US2176500A Process of concentrating aqueous aliphatic acid solutions by means of seven carbon atom aliphatic esters and five carbon atom aliphatic alcohol entrainers
A rather non exhaustive list of azeotropes related to distillation.
Interesting to note that many high boiling esters form minimum boiling ternary azeotropes with their parent alcohols and water.
Some of these mixtures will be unlikely to occur due to a lower boiling mixture removing all of one of the components.
For instance diacetyl/ethanol should get the vast majority of diacetyl before the diacetyl/water boiling point is reached.
