Gin filtration
Posted: Thu Sep 06, 2018 5:58 am
by birgirms
Hey gang.
Are you filtering your gin prior to bottling? Or do you feel that takes away too much of the flavour?
Re: Gin filtration
Posted: Thu Sep 06, 2018 6:04 am
by fizzix
Definitely NOT carbon filtering. Too much a flavor killer.
I have a fine mesh (or you can use a coffee filter) to filter the botanicals/particles out.
Re: Gin filtration
Posted: Thu Sep 06, 2018 6:18 am
by Expat
Why would you need to filter your gin?
Assuming you started with a clean neutral, there should be nothing you'd want to remove. If you're getting louching, add more neutral at bottling proof until it clears.
Re: Gin filtration
Posted: Thu Sep 06, 2018 9:02 am
by Saltbush Bill
How the hell are you guys making your gin that you need to filter it.?
Re: Gin filtration
Posted: Thu Sep 06, 2018 10:11 am
by fizzix
Saltbush Bill wrote:How the hell are you guys making your gin that you need to filter it.?
Odin's Gin. The botanicals go right into the neutral for 2 weeks maceration.
Re: Gin filtration
Posted: Thu Sep 06, 2018 11:33 am
by Expat
Depending on your setup and recipe you may not even need to strain the botanical before running them.
"...Prior to bottling" would suggest that it's already been run; The final gin distillate should require no filtering.
Re: Gin filtration
Posted: Thu Sep 06, 2018 5:49 pm
by bitter
If you gin is cloudy at 40% take some neutral and up the % I normally do 43% for gin.. but 46% for most other bottling so will go upto there.
If a lot of the oil come over things can be cloudy. Just up the % a little till it goes away. Its a good thing that means you go the flavor your after.
B
Re: Gin filtration
Posted: Thu Sep 06, 2018 6:37 pm
by Saltbush Bill
Time will also clear cloudiness.
Re: Gin filtration
Posted: Thu Sep 06, 2018 6:42 pm
by Fiddleford
Saltbush Bill wrote:Time will also clear cloudiness.
Wish I knew that 2 years ago, I made a gin and had to keep it a 60% strength so it wouldn't cloud up
Re: Gin filtration
Posted: Fri Sep 07, 2018 5:15 am
by Kareltje
After macerating I sieve the botanicals. Put part of them in tea eggs in the boiler and part in the ginbox.
After distilling I just store the gin at 80 or 85 %ABV and dilute to 43 %. I do not mind louching, as I consider it a sign of enough taste.
