Water in the summer, Air in the winter
Budapest8485
Post by Budapest8485 »
We don't get a lot of time without HVAC assistance where I live. I've studied the different condensing methods and find air cooled very interesting. The prospects of using the heat to supplement my winter heating expense is interesting to me. I don't like waste...saving water and supplementing heat makes a lot of sense to me.
I don't want a long condenser with a series of computer fans. For air cooling, my preference is to use a box fan with a series (spread out shotgun) of tubes splitting and then coming back together for collections. Looking through some of the plans I've seen on the site, a manifold that constricts the vapor flow farther from the source insures even distribution. This looks like the duct work running through some of the building I've seen...it gets smaller the further it is from the source of heat/cooling.
I'm not aware of any ready to buy manifold that will provide increasing restriction as it reaches the end of distribution. I have to make it myself. This will push me further beyond my current skills and abilities. I will have to grow and learn and create what I need...unless the collective (this site) tells me there's an easier way!
Thanks in advance!
3 x 60 inch Bokabob, 8 gallon boiler, 4500w
3 inch pot still head, reduced to 2 inches, then to 48 inch 1/2 condenser. 8 gallon boiler, 4500w
HDNB
Re: Water in the summer, Air in the winter
Post by HDNB »
i use a recirc tank. it was getting too hot on longer runs, so i added a car radiator, electric fans and 12vdc power supply. it was a little expensive at 300 all in, but it is very effective at keeping cooling water cool.
now i drink for evil.
Stew8
Post by Stew8 »
Hey Buda
I made a double barrelled air cooled condenser and attach a Liebig in the summer.
It needs to run slowly in the winter but it works.
If you want more photos send me a pm.
viewtopic.php?f=50&t=70265
Budapest8485 wrote:...unless the collective (this site) tells me there's an easier way
Here's an experiment I did awhile back.
viewtopic.php?f=87&t=56652
Budapest8485
Stew8 wrote:Hey Buda
That's a different look than I've seen before...like coils of wire instead of fins. The aspect of warming the house with the heat from distilling is appealing. Sounds like i might have to slow down some though. Thanks for sharing!
Budapest8485
I think I'd probably go the same route as you with building the manifold. I recently learned how to "tin", so I would probably create the cone shape using that technique to bring the pieces together.
The manifold was pretty copper porn
Unfortunately the manifold was inferior to connecting the condensers end to end.
In electricians terms, series worked better than parallel. :lol:
Long story short, the Zig Zag air-cooled condenser I built last, worked better than the pretty manifold I built first
Budapest8485
So doing this in series, you have to put the tubes on a slit diagonal with gravity to keep it moving the right direction?
A pic is worth a thousand words.
Budapest8485
shadylane wrote:A pic is worth a thousand words.
Yep, that's what I figured...slight diagonal to keep it moving. Maybe I'll do something like that. Maybe I can get something on the cheap as salvage to assemble it. I'll make sure there are no existing solder joints to ensure a lead-free condensor. I already have the fan.
