Reading the Proof and Tralle
Duckhunter18
Post by Duckhunter18 »
Ok im still having alittle trouble reading my Proof and Tralle hydromter?? Which of these pics do i go off of?? Im cofused at what Part of the Meniscus to go off of??? I know about my heat deductions and all. But which line do i go off of? In the pics i posted you will see im pointing at both lines?
Proof tralle 2
Proof tralle 2
Proof tralle 1
Proof tralle 1
Re: Reading the Proof and Tralle
pic 1. The correct measurement is at the bottom of the miniscus, not the top.
p.s. - Danespirit wrote a great thread about using the P&T hydrometer. There’s a hotlink in my signature. Have a look...
Duckhunter18
So eye level at the top of the Meniscus?or eye Level at the bottom of the meniscus?? WHICH PICTURE IS CORRECT? Proof tralle 1 or proof tralle 2?
OtisT
Post by OtisT »
I use an old frog hunting trick to help me read these. First, SS is exactly correct.
Movement of my head up/down helps my brain see the proper line. It’s all about perspective, and sitting in one place only gives you one perspective. Look at the top and move your head up and down slowly. Your brain will tell you what line is just at the bottom of the maniscus.
Otis
Duckhunter18 wrote:So eye level at the top of the Meniscus?or eye Level at the bottom of the meniscus?? WHICH PICTURE IS CORRECT? Proof tralle 1 or proof tralle 2?
I answered this. Go reread my post.
6 Row Joe
Post by 6 Row Joe »
Bottom of the meniscus but don't sweat the small stuff. Unless you work in a lab or a commercial distillery a point or two doesn't really matter.
Duckhunter18
So my deduction is 2 degress what is my Correct on tralle reading?
Duckhunter18 wrote:So my deduction is 2 degress what is my Correct on tralle reading?
I read 88%ABV. You?
Duckhunter18
I read 87%ABV with the 2 degree deduction i came out to 85%ABV
Duckhunter18 wrote:I read 87%ABV with the 2 degree deduction i came out to 85%ABV
....close enough for the fence builders....
Oldvine Zin
Post by Oldvine Zin »
I see it as 87 1/4 so 85 1/4 + or - a few points :lol: :lol:
I wouldn't sweat a couple of points
OVZ
Oh and it's really difficult to tell from only one perspective that the photo allows
Duckhunter18
Ok which line do i take my reading from P1 or P2
Duckhunter18
Here are new pics.
Pic
Pic
Duckhunter18
Pic
Pic
You choose.
We’ve told you how to read the hydrometer...now, use YOUR eyes and read to correct one.
This game is getting old very fast.
DetroitDIY
Post by DetroitDIY »
Duckhunter, you want the predominant surface, not the edge where the meniscus typically rises up along the wall of the tube or the alcoholometer due to surface tension. Look for the main flat surface, wherever that is, and that's what you should visually project against your alcoholometer. In your initial post, the right plane to look for your titled Proof tralle 2, but it was the top image (thus SS told you the first image).
With water (and our distillates), the meniscus will be at the bottom, unless you're carefully on the precipice of overflowing a vessel (which can create a positive meniscus). Some liquids have the opposite trend. Check our this link for an example and someone else's explanation: https://water.usgs.gov/edu/meniscus.html" onclick="window.open(this.href);return false;" rel="nofollow
6 Row Joe
Post by 6 Row Joe »
88°
OtisT
Post by OtisT »
Hope this helps you duck hunter. Otis
Reading proof and trall
Information is in the New Distillers Reading Reading Lounge Using a Hydrometer.
seamusm53
Post by seamusm53 »
My palate can't tell the difference between 85 and 90% so worrying about a 2% difference in the reading is personally needless - I can get blitzed on less. More important, the traille devices are calibrated for a specific temp and the wrong temperature can make for measurement errors way outside that 1-2% difference between the top/bottom of the meniscus and errors caused by parallax.
