ptfe
migoplumber
ptfe
Post by migoplumber »
my 1st question - be gentle with me.
i have seen that everybody recommends using ptfe for still seals.
here in the uk, we barely use ptfe anymore, we have switched to loctite 55.
dont get me wrong ptfe is still readily available but we have just had better results and less failings with the loctite.
the loctite is a paste impregnated string, ideal for steam as well as gas.
link is
https://www.rapidonline.com/Loctite-483 ... gKq5fD_BwE" onclick="window.open(this.href);return false;" rel="nofollow
what are your thoughts ?
thanks
shaun
hpby98
Re: ptfe
Post by hpby98 »
I would think potable water safe, vs ethanol vapor safe are two different things. PTFE is industry standard for gaskets...
https://www.calpaclab.com/teflon-ptfe-compatibility/" onclick="window.open(this.href);return false;" rel="nofollow
Any documentation on the loctite compatibility?
Single Malt Yinzer
Re: ptfe
Post by Single Malt Yinzer »
The vapor proofing is why it is needed, the chemical resistance is why that particular product is used. Meaning the alcohol will not leach any chemicals into the spirit. High temp alcohol is very reactive. Most chemicals will react with it in some way. It's also why flour seals are used in lieu of PTFE in situation where PTFE won't work properly.
https://homedistiller.org/wiki/index.php/Flour_Seal" onclick="window.open(this.href);return false;" rel="nofollow
Re: ptfe
https://www.henkel-adhesives.com/au/en/ ... te_55.html
Certified to ANSI/NSF Standard 61 for use in commercial and
residential potable water systems not exceeding 82° C. Note:
This is a regional approval. Please contact your local Technical
Service Center for more information and clarification.
What is it about that quote from a Loctite 55 data sheet that makes you think that it's suitable for distilling?
migoplumber
Re: ptfe
okay guys, thank you. i will investigate further.
