I can't seem to find the strength of denatured alcohol (only the strength of the methanol).
I assume ethanol can be used in a laboratory alcohol lamp but at what proof?
Alcohol lamp?
Benredbeard
Alcohol lamp?
Happy bees, home brews, and two green thumbs.
Re: Alcohol lamp?
Methylated spirit is Ethanol that has been denatured by adding a bit of other stuff to make it unpalitable . But it is basically just Ethanol and has an abv of 95% typically . The denaturing agent varies from country to country but the product has the same purpose .... something that will burn and clean as a solvent .
So yeah , 95% ethanol will work in a spirit lamp .
At work they use denatured ( methylated ) spirit in the Spirit burners ..... thats what they are designed to be used on .
- kiwi Bruce
Re: Alcohol lamp?
Isopropyl alcohol at Walmart is 75c a pint.Yummyrum wrote:Methylated spirit is Ethanol that has been denatured by adding a bit of other stuff to make it unpalitable .In the US methanol is used to make the ethanol very toxic, other countries now use isopropyl alcohol, which will make you sick but not kill you. Isopropyl alcohol is cheap, clean burning and a good lamp fuel also, if used by itself But it is basically just Ethanol and has an abv of 95% typically . The denaturing agent varies from country to country but the product has the same purpose .... something that will burn and clean as a solvent .
hpby98
Re: Alcohol lamp?
Google “penny stoves” Or “backpacking ethanol stoves”
https://www.outdoors.org/articles/amc-o ... ter-stoves" onclick="window.open(this.href);return false;" rel="nofollow
I did a test with my penny stove against a buddy with his tri-mix
Was within seconds to boil 1 liter of water while camping
OtisT
Re: Alcohol lamp?
Here are a few little penny camp stoves I made for fun. Once lit, these things crank out the heat.
Otis
hpby98
Re: Alcohol lamp?
I agree. Back in the good old days when you could find Heineken cans as barrels.OtisT wrote:Here are a few little penny camp stoves I made for fun. Once lit, these things crank out the heat. Otis
I even made a few out of the large cans too.
seamusm53
Re: Alcohol lamp?
Alcohol stoves are amazing as light-weight and simple backpacking stoves. The only down-side is that burning alcohol is almost invisible in the day and dangerous.
hpby98
Re: Alcohol lamp?
A little salt adds color... but I find I get blue / yellow flames with mineseamusm53 wrote:Alcohol stoves are amazing as light-weight and simple backpacking stoves. The only down-side is that burning alcohol is almost invisible in the day and dangerous.
