My C,U,B pot still is all finisted shit hot
Posted: Mon Jun 16, 2008 2:40 am
by sconly
Re: My C,U,B pot still is all finisted shit hot
Posted: Mon Jun 16, 2008 3:02 am
by jdonly1
Posted: Mon Jun 16, 2008 3:07 am
by sconly
come on a bit harsh at least my is welded my then i can say for yours
Posted: Mon Jun 16, 2008 11:57 am
by punkin
Nice looking still. The easiest way to get the silver solder to run, is to get it damn hot. Just on the edge of burning a hole in it.
You don't need flux either on copper to copper joints, shine em up with a bit of steel wool and go for it.
Use the heat to draw a little solder right round the job, watch how it follows the heat and apply the flame to where you want it to go ie; drawn right in the joint. It'll never have a hole in the solder if you apply enough heat right around it, and it was clean to start with.
You can leave it at that for a nice neat joint, but i like to go back round with a slightly lower heat (hold the torch further away) and apply a thick seam of solder right around where the two pieces join.
You shouldn't need to add more solder or flux to fix those joints, just get it hotter.
I do a lot of silver soldering most days.
Posted: Mon Jun 16, 2008 5:25 pm
by Aussie Beamophile
Hey Trent, well done.
I'm not gonna knock your soldering coz I haven't posted pic's of mine yet.
Did you end up getting your fittings from Parkwood Plumbing?
Scott.
Posted: Wed Jun 18, 2008 11:56 pm
by sconly
Aussie Beamophile wrote:Hey Trent, well done.
Scott.
cheers Scott yer i did end up going to Parkwood Plumbing once i found there trade store went to there display centre first
Posted: Sun Jun 22, 2008 9:10 pm
sconly wrote:Aussie Beamophile wrote:Hey Trent, well done.
Scott.
Glad you found it ok (eventually).
I got mine fired up with it's first UJSM on Sunday. The pictures are on this forum under "The Dalek"
Cheers
Scott
