Strip Run Turned Brown
Opdog
Post by Opdog »
I stripped a batch of SCOD’s neutral wash the other day. I ran it through my modular flute in pot mode. I pulled the plates and had all 5 cans in the tower enough for the shotgun to sit high enough to properly fill my jars. The wash had been sitting around for a few weeks and had cleared well. The boiler was filled with about 12 gallons of wash and I ran it full tilt for the whole of the run. The distillate came out clear, but a yeasty smell pulled through.
I typically collect 200ml in mason jars. I did that this time as well, mostly to stick to my standard procedure. I know that I didn’t really need to worry about it on the stripping run but I like to be consistent. I tossed the fores and dumped the rest in two large pickle jars (I usually use these to store tails - the inside of the lids have PTFE inserts) with a little bit of soda ash. I usually put the soda ash in the boiler but tossed it in the pickle jars so that I wouldn’t forget to do it. I tossed in double what I would normally use, as this run will be combined with a run from last week for the spirit run. I didn’t think that leaving it overnight would cause too much trouble.
I came out the next day and both jars have turned a light golden brown. I ran them through a coffee filter to remove the soda ash and to see if there was any particulate matter in there. The only thing I got in the filter was the soda ash. The coffee filters were not discolored after use. The distillate was still brown. It is now darker than the wash. I’m stumped.
I don't know why the pic is sideways. It was the right way up when I took it. Also the weird blur in the middle it the back of the tape I use to label things.
I’ve been doing this a while and have never had anything like this happen before. I though that maybe it was some kind of weird puke. I rarely run the element full out on a run. The thing is that I run a 2” to 4” conical connector from the boiler to the base of the flute and there is about 3 feet of vertical rise before the bend to the condenser. I know that washes foam more than mashes, but that would need to be quite the puke. Admittedly I was not looking through the site glasses as I had pulled the plates, so it is possible that it foamed up and puked and I didn’t notice. The stream out of the condenser never really wavered. I got a little concerned that I was pushing too hard and dropped the heat a little about half way through. I collected pretty far down into the tails as I was planning to re-distill the whole thing the next day anyway (hence the soda ash).
I've only made this wash one other time, but it worked well and was probably the cleanest neutral I have ever run. The last run also had a slight yeasty smell that didn't carry over much after the spirit run. The wash fermented clean and I didn't note any issues during the ferment.
Any ideas as to what may have caused this? Also do you think it will be safe to add it to the spirit run?
I've stopped fighting my inner demons. We are on the same side now.
This topic has 4 more replies
Register Login
