Foreshots on second run
Posted: Thu Jun 19, 2008 12:08 am
by sconly
ok so im using my pot still to do quick stripping runs then running it back through a reflux still on the strip i collect the so Foreshots do i need to get the Foreshots on the second run and if so how much for a 25L amount
cheers
Re: Heads on second run
Posted: Thu Jun 19, 2008 1:38 am
by punkin
You may be getting the terms 'heads' and 'foreshots' confused.
Foreshots are the bit that first comes out that you dispose of. Not for drinking.
The collective wisdom here being that 100-200ml each run will do ya for most washes and you chuck em out on every run.
Heads being the next portion you collect in numerous small jars and decide whether to keep as drinking fuel or to recirculate as feints in your next run ( or chuck away too as some here do).
NowGoBackAndPracticePunkin
Posted: Thu Jun 19, 2008 1:56 am
by sconly
cheers punkin yer got the 2 mixed up so how much so around 100ml 200ml on the second run is Foreshots so bin it is that right
Posted: Thu Jun 19, 2008 2:04 am
by punkin
Sound right to me. I think the reflux boys chuck out less, but 100ml is about what i chuck out for a 25 litre wash.
100 - 200 ml on a second run too
Posted: Thu Jun 19, 2008 2:20 am
by HookLine
punkin wrote:Sound right to me. I think the reflux boys chuck out less, but 100ml is about what i chuck out for a 25 litre wash.
Correct. But only because it is more concentrated. I throw about 100-150 ml from a 60 litre sugar wash.
Re: Foreshots on second run
Posted: Thu Jun 19, 2008 2:30 am
by sconly
cheers for that Punkin and Hookline
Posted: Thu Jun 19, 2008 4:06 am
by Husker
punkin wrote:You may be getting the terms 'heads' and 'foreshots' confused.
I will state the reason again,
The reason that foreshots are "removed" from the cycle, is so that they do not accumulate and "build up" on subsequent runs. IFF you "recirculate as feints in your next run", and then do so for the run after that, and the run after that, ... adding in the feigns from each prior run, if you DID NOT remove the first foreshots (which are almost entirely higher alcohols, with little or no ethanol), then the head materials would build up, and things would start to get dangerous (and hang over juice would be all you are making). By removing the foreshots from this cycle, you are able to add the feigns from each run, into the next run, to extract the ethanol from them, without building up harmful substances.
Exactly how much foreshots to pull out, will depend upon, 1. How clean the original wash is. 2. How big each run is. 3. The type of run (reflux stills can concentrate more efficiently than a pot still, and thus the foreshot cut can be somewhat smaller).
The rule of thumb of 100-250ml per 25L is pretty safe. Smaller stills will have to up this ratio somewhat, and I think that larger boilers could actually scale this ratio down a little. If you were running a 2500L boiler, I do not think you would have to remove 25L as foreshots. I bet that 3L-5L would be about the right amount to remove from the cycle (if you were batch running a still of that size).
To re-iterate: Foreshots are removed so that the higher alcohols do not build up on batch distillations where prior runs feigns are recycled back into the next run. However, simply properly following the "rule of thumb" instructions of removing the first 150ml from your run as foreshots (from all runs), will keep you safer, even if you do not know why.
H.
Posted: Thu Jun 19, 2008 11:41 am
by punkin
Husker wrote:punkin wrote:You may be getting the terms 'heads' and 'foreshots' confused.
H.
Have you just quoted me by mistake Husker or are you addressing me with this?
I only ask as i have read every post on the site at other times and have read this explanation at least fifty times, so am very well aware of the reasons why....even if i don't take the time to type it out when i post...
You can go back to ignoring me if it was posted for sconly's benefit
MakesGoodFirelighterAndHeaterFuelPunkin
Posted: Thu Jun 19, 2008 12:11 pm
by Husker
punkin wrote:You can go back to ignoring me if it was posted for sconly's benefit
lol, I do not ignore you punkin. Not at all
No, you just got caught up in the quote. The message was for sconly or any one else who is overly concerned about the why.
On many types of safety issues, it is better to simply blindly follow the recommendations of people that have been doing this a LONG time, even if it does not make sense (and no, that comment is not directed at u punkin
H.
Posted: Thu Jun 19, 2008 12:22 pm
by punkin
Just checking....
I'm a sensitive guy.
My eleventeen year old grandaughter summed it up in the nicest way when she said to her little sister ...
" Don't worry about him, he's complicated..."
LiableToTizzysAndNeedReassurancePunkin
Posted: Thu Jun 19, 2008 6:05 pm
by trthskr4
punkin wrote:Just checking....
Jeez Punkin, I had you pegged as being thirtysomething, never figured you as a G'Pa.
Man I wish we could all get together and meet each other. I think that'd been the coolest damn thing.
It's all fun and games til someone brings the popo.
Posted: Thu Jun 19, 2008 6:09 pm
by jdonly1
trthskr4 wrote:punkin wrote:Just checking....
I guessed he was an old bugger
Sorry mate,only joking
Posted: Thu Jun 19, 2008 6:43 pm
by trthskr4
Yeah JD. I have a quirky way of putting faces and such on folks after seeing them write for a while or hearing them on the phone. Then I either meet them or something like this and I have a hard time changing my mental image.
Posted: Thu Jun 19, 2008 7:06 pm
by Dnderhead
Deception may fool ya
many years ago used to be on CB a lot - voice =mental image does not equal real life ( Iv got kids/ grand kids? or was that
grate grand kids?) I got lost somewhere.
Posted: Thu Jun 19, 2008 9:29 pm
by Aussie Beamophile
I wondered why there was so much wisdom on this site.
It's patronised by wise ol' grandads!!!
I'm feeling decidedly younger (and smarter) just by being in your presence.
How do you guys keep the nurses at the home from confiscating your stills?
Posted: Fri Jun 20, 2008 12:04 pm
by punkin
I'm somewhere in between where you lot are thinking...early forties, i inherited the daughter that had the grandkids (well before she had em) and my son is 24 this year....
FatTattoedBuzzCutAndSarcasticIfThatHelpsPunkin
